Question about Olympus Camedia C-5000 Zoom Digital Camera
Damaged monitor I've got a cracked monitor, are there replacements monitors available for a do it yourselfer? If so, where?
    Genius:
  • 1,689 Answers
This is factory level service only, unless you have a lot of camera service experience and the tools to do a proper job. In anycase the manufacture may not sell the parts to any non authorized service person.
Jerry G.
Posted on Apr 15, 2008
My monitor flickering when I touch or tight the monitors VGA cable then display will come what is the problem of the monitor
I think your cable is damaged.
I've you can pull your VGA cable (BLUE) out of your monitor, you can replace it by a new one.
I've not, you need to get it fixed.
Please rate my solution.
Thank you for using FixYa.
Jun 24, 2011 | LG Flatron L1715S 17" LCD Monitor
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
White display on my lg flatron L192ws
Most common problems with LCD monitors arises due to weak or damaged capacitors. Disconnect the power and signal supply from monitor, then open the case gently. Use a flat screwdriver for pry opening the case, after removal of screws. Here you have to look for faulty capacitors on the circuit. On the PCB of the monitor, check each capacitor for deformation/leakage around it. In case of any doubt, it's better to replace the capacitor, as they are inexpensive. The only thing is that you should use the correct rating capacitor for replacement. You will need a soldering iron, and at best a multimeter for carrying out the job. After doing all this, assemble the monitor back, and your monitor will be working fine.
Caution : If you are finding yourself uncomfortable with all the work doing yourself, then ask for help from a qualified technical person.
Nov 01, 2010 | LG Flatron 563LE 15.1" LCD Monitor
Black marks on screen i think it needs a degaus but dont know how to do it
LCD monitors do not need degaussing. They operate in a completely way to CRT monitors.
Tiny black marks are most likely dead pixels, if the black marks are large then the LCD screen may be damaged (cracked glass).
This type of damage cannot be repaired simply, the screen needs to be replaced.
I suggest you put your money towards a new LCD monitor.
Sep 03, 2010 | LG Flatron L1710M 17" LCD Monitor
HP G60-235DX--LCD screen cracked
yes, there is a way, it is detailed in the HP Service Manual found online
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
start at page 63 of the pdf (refered to as section 4-24 in the manual text) and go from there!
Let me know if you have any questions.
Thanks,
Mike
May 17, 2010 | HP G60-235DX Notebook
Pink color
check the led back light of your monitor. I you cant do-it-yourself better to go to service center
Jul 30, 2009 | Samsung SyncMaster 920NW Monitor
Cracked Monitor
Hi...there,
Well sure, if you don't mind pay double the prices... My advised, give yourself a new monitor, since the holidays is coming... saved you the headached and $$$...
Oct 07, 2008 | HP LP2065 Monitor
Lcd screen is broke
The LCD panel may be available as a replacement part, but the cost will be close or exceed the cost of a replacement monitor. Don't waste your time. Purchase a replacement.
Dan
Mar 25, 2008 | Scanport 17" LCD Monitor
SD300 Monitor Problem
This sounds like a cracked LCD screen. If so, it requires replacement. There are many sites available on the web that will do this for you for a fee.
It is also possible to fix it yourself if you can find a replacement screen, and if you are familiar with basic electrical safety (there's a flash capacitor inside your camera that can give you such a ZAP!).
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Oct 24, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Monitor sounds?
It happened that to me last year. After 2 weeks of cracking sound symptoms, my monitor begun to blackout - no video signal but the indicator light is still available. I checked it inside using my tester, one of its transistor was burned-out. I tried to replace it and its working up to now. Possible cause of this is probably overuse of monitor without proper ventilation causing electronic components to overheat. Try to bring it to an authorized TV repair man in your local area for proper diagnosis - Don't try to fix it yourself. He's the right expert to that.
Apr 04, 2007 | Kogi L7CH Monitor
Olympus Camedia C-5000 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
