Televison & Video Logo
Posted on Mar 22, 2009
Remote control codes needed
I want to program my time warner remote control to my mitsubishi tv (codes)
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Mar 23, 2009
Anonymous
Contributor
Level 1:
Answers
31
Questions
Helped
14126
Points
72
Turn your device on, press device key(tv,dvd,etc) press and hold Setup (led blinks twice), pres 9-9-1(led blinks twice) press power key , press channel + repeatedly until device turns off, press setup untill device turns off. good luck
Universal remote control programming
If you wish to get more details about how to program a remote control, check this link. http://electrohelponline.blogspot.com/ Set-up code list and set-up procedure to many popular brand remote controls are given in detail. Pull up older posts there, either by its left side bar, or see it in Timslide option.
32helpful
2answers
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
How do i program this remote to my time warner cable box
Time Warner is most likely made by another company and they are not listed on the programming documentation. You can try looking online to see who makes your Time Warner box. You should be able to program the manufacture off of the program list. The universal code for this remote is 8107 and 8108 which may work as well. To program the remote press set and the light next to set will start flashing. Press the desired component button ex(TV , VCR, CBL, DVD). Next enter the code 8107 and press ENTER. The set light should no longer be flashing. If 8107 does not work try 8108 using the above info.
6helpful
2answers
Need codes for olevia tv
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
2answers
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Programming remote control to Cable TV Box
What you need to do is contact the manufacturer of either your remote control otherwise the manufacturer of the Time Warner [aka: cable providers some times also have the info on file for their customers] they store the code information within their internal systems for their customers such as yourself. Otherwise there is normally a paper insert with the remote control or the Time Warner that would list the info for select manufacturers on there. Toshiba has pretty universal IR signals/codes so you should be okay when trying to program in the codes. The manufacturers can also assist you through the steps--believe me it can get frustrating some times!
I feel like an idiot
I'm sorry to say that some TV's just plain don't work with a universal remote. If you have used all the codes that came with the remote, contact Time Warner support and tell them.
Unfortunatly the codes are not the TV's they are the Remotes, so unless Time Warner has a code that works or can walk you through the SCAN process successfully you might not be able to use it.
//D
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
