Question about Kenmore 16225 Grill
Gas Grill won't light
I have a Kenmore 16228 gas grill and suddenly the burners won't light.
SOURCE: Kenmore Elite Grill will not start
The gas regulator that attaches to the tank may be bad.
Posted on Jun 27, 2007
SOURCE: gas grill lights but doesn't get very hot
There's a good chance your LP tank isn't putting out enough propane because it thinks there's an overflow. In short, if you don't light the grill fast enough, Propane flows back to the tank and a safety feature limits further output. Shut the valve and disconnect the tank, press your ignition switch a few times, then reattach and follow the manufacturers directions for lighting the grill. This will probably fix it.
If not, check for leaks in the hose with soapy water and make sure you still have a full tank!
Posted on Apr 07, 2008
  • 4 Answers
SOURCE: Kenmore gas grill 141-16228
There is an Englewood, CO, retailer called Appliance Factory Parts. They sell parts for discontinued and old model gas grills., at (800) 955-7075. The burner can be obtained from them or a local gas barbeque store (I found out they are interchangeable with new model grills), but the grilling and lava rock grates/grids were hard to match and I got them from Applied. I rebuilt a 1992 model Kenmore grill.
Posted on Jun 19, 2008
SOURCE: gas grill ignitors
I recently moved. When the grill arrived to the new home I had to purchase a new propane tank to replace the old one. The grill will not light. For some reason it isn't getting any gas. Any suggestions on what the problem might be?
I tried the obvious... tightening the connections, trying to light it manually etc.
Posted on Jul 13, 2008
  • 388 Answers
SOURCE: I need 3 burners for Grand Gourmet Gas Grill Model No. GBC621A-M
Try this link:
It should bring you right to your specific grill and list replacement parts including burners.
Posted on Sep 08, 2009
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Posted on Apr 30, 2010
0 characters
1 Points
I have a kenmore quantum series propane grill which i cleaned and now i cant get it to light and i smell the propane what should i check?
Donna, are you saying the ignitors are not working or that the burners just won't light? Not even by match lighting them? All this makes a difference in providing a solution for you.
Please advise. Thanks
Jul 29, 2011 | Kenmore 16228 Grill
Kenmore 800 grill replaced ignitor i get a spark but it won't light
First and foremost, make sure the gas tank valve is turned ON and that there is adequate gas in the tank. If that all checks out, do the following:
1. Turn the gas tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow motion,
4. Once the valve is full open, light the burner farthest from the tank first and turn it to HIGH. Did the
burner light and does the flame height look correct? If so, light the remaining burner(s) the same
way. Did all the burners light and the flame heights look normal. I so, you just solved the
problem (with a little help).
Remember to always turn the tank valve ON Very, Very Slowly.
If it didn't solve the problem, you will need to replace the grill's Regulator/Hose Assembly. You can purchase on at any home center or hardware store that sell gas grills and accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 18, 2011 | Kenmore 800 sq. in. Cooking Area Gas Grill...
Grill won't heat up over 250 degrees
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
Sep 04, 2010 | Kenmore 16228 Grill
Just hooked up new propane tank and grill won't ignite either with starter or matches
Turn gas tank off and disconnect from grill. Check burners to ensure there is no blockage and reconnect tank.Open gas tank slowly, some grills have a sensor to detect leaks and automatically shut off gas. Opening the tank fast can cause this safty device to falsely read the sudden gas flow as a leak. If you still can't light the grill check all fittings for a leak using soapy water.
Apr 28, 2010 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Gas is not getting to the burners on my Sears Kenmore gas grill.
check if regulator fully screwed to tank, turn on tank,then last burner,should hear/smell gas. if not replace regulator
Jun 25, 2009 | Kenmore 16225 Grill
Low pressur on gas grill
orfices are possibly clogged with spider web
and the check to see if your dial on tank is fully open and check to see if your tank is almost empty...
Jun 01, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Glas flow will almost shut down once i turn on the second burner
hi my name is mark, let me see if i understand your problem. you light the 1st burner and get a good flame. you light the 2nd burner with the 1st burner lite and it starves both burners of gas. if this grill is a lp grill and you have propane in the tank. the regulater is the problem.
Feb 22, 2009 | Kenmore 16228 Grill
Gas grill lights but doesn't get very hot
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Mar 10, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
I would love to know the answer myself, I can't figure it out now that I have the grill half taken apart.
Jan 14, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Kenmore 16225 Grill Logo
763 people viewed this question
Top Kenmore Grills & Smokers Experts
Dan Webster
Dan Webster
Rich Florenzen
Are you a Kenmore Grill and Smoker Expert? Answer questions, earn points and help others
