Question about Radio Shack Pro-94 Scanner
1000 scanner radio shack
Won't receive even weather when hit scan shows all channels locked tried 2 and 9 trick and tried to unlock key pad nothing seems to help
  • 56 Answers
Press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Posted on Sep 12, 2007
SOURCE:
Getting scanner to scan
Make sure that the keypad isn't locked. See if there is a little key in the display. If yes, then hold down the lock key to unlock the keypad. Next, hit 'scan' and you will have to select a group to scan, so press the #1 or #2 button IF you have frequencies loaded into it. Can you press the WX button to hear the weather? Let me know. Good luck.
Apr 20, 2014 | Radio Shack Pro-95 Handheld Scanner
All the channels are locked out so I can not scan
Hi Loris,
First, you turn on the radio, then press Mon/Hold key, then press No. [1] key. if your scanner is programmed, you should see the frequency displayed on the screen, example: 162.9875MHz, also on the screen you will see L/O icon, press L/O key and it will no longer show, then press Mon/Hold key and you'll go to channel [2], follow the above steps until you've unlocked all channels that are programmed in your radio scanner, when complete, press scan and your scanner will stop on any transmission it receives.
If, however, you have not programmed any frequencies into your scanner, all you'll get as a frequency reading: 000.0000MHz, meaning you won't hear anything.
Programming frequencies is easy, but you need to have a hard copy of your favorite frequencies for your location, these can be obtained from: www.radioreference.com where every USA state is covered, just copy and paste into any word processor and print out.
You need to do the following to program.
Press the [Prog] key, then select the channel to program to, then enter the frequency (key by key) leaving nothing out, that is as it's printed on the frequency list including the [.] decimal point, then press [Delay] key, then press [L/O] key (if icon is shown on display), then press [Prog] key again to go to the next channel, continue to follow the above steps until you have enough frequencies programmed to listen to.
Only select frequencies for your location, as some will not be available even if in your state.
I hope I have been of help to you.
Cheers,
Peter
Feb 08, 2013 | Radio Shack Pro-96 Scanner
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
Will not scan. Screen shows banks and scan up message.
Try this,press manual,turn squelch to silent,press scan. hope this helps..
Mar 20, 2010 | Radio Shack Pro-95 Handheld Scanner
RS Pro 2020 Scanner won't come out of scan mode, pad ineffective
If you mean a Bearcat 2020 radio, then that unit is ancient, and I'm amazed that it still works. If you're only monitoring one frequency, you can get a really cheap scanner to do that and replace the 2020.
Aug 01, 2009 | Radio Shack Pro-2018 Scanner
Radio Shack (Realistic) PRO-2020 Scanner stuck in Scan Mode
Sounds like old age - the 2020 is nearly 30 years old! Have you tried just using the LOCKOUT feature on all channels except the you want? How about just programming the same frequency into all 20 channels?
Jul 25, 2009 | Aiwa AV-S17 Receiver
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-94 Scanner Logo
202 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
