Question about Sony Handycam DCR-TRV19 Mini DV Digital Camcorder
Video capture problems
After years of trouble-free capturing, suddenly, I have problems with both camcorders - a Sony Handycam and a new Panasonic (both MiniDV). Both connect via firewire. images record on the camera perfectly and play without problem via cable to the TV - but, when I 'capture' them via firewire to any of several programs, they are choppy and 'broken.' So, the problem appears to not be the cameras. I have also replaced the firewire cable - no change. Any help for me out there? Thanks. David
  • marindavid Aug 27, 2007
    Advice offered to change compression rate was not helpful. Any other ideas/suggestions?
    Thanks.
    David
  • marindavid Sep 24, 2007
    I solved my problem by moving the temp captured files to a different hard drive. Turns out, the one I was using was just too full to allow for more perfect rendering and capture.
    Good luck with yours!
    David
    Problem Solver:
  • 12 Answers
Sounds to me that the bit rate on your PC or capturing device is not as high as that now available through the firewire ports. Try increasing the bit rate in your settings and see if that helps. Or have you always used firewire?
Posted on Jul 28, 2009
SOURCE:
I have a SONY handycam DCR HC 46E. I am unable to transfer video from Mini DV cassettes to my PC(with windows 7 ultimate 32). I have also downloaded and installed PMB. With that I am able to transfer...
I'm sorry for the difficulties you're experiencing in transferring videos from the Camcorder to the Windows 7 Operating System. The USB streaming driver for the Camcorder is not available for Windows 7 OS from Sony at this point. Hence it is not possible to transfer videos using USB interface. You may use i.LINK or A/V interface to transfer videos from the Camcorder to the Computer which is running on Windows 7 Operating System. If your computer does not have the i.LINK port, you may purchase an i.LINK capture card to resolve the issue.
Please follow the steps to transfer video to a computer using an i.LINK connection (IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must be installed on the computer. Depending on the computer manufacturer, various video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft Windows Movie Maker, etc.) may be available or already installed on your computer. If necessary, contact the manufacturer of your computer for further information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate Plus software for video capturing. Some VAIO computers also include Click To DVD software that will allow video capture to the computer hard drive or directly to a DVD.
  1. Connect an i.LINK cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
i.LINK Cable.
i.LINK port.
  1. Connect the other end of the i.LINK cable to the computer.
NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  1. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  2. Cue the camcorder tape to the beginning of the video footage.
  3. Turn on the computer.
  4. Start the video capture software on the computer.
  5. Begin playing the recorded video in the camcorder.
  6. Begin importing the video with the capture software.
It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Thanks for understanding. Please let me know if you require any clarifications.
Jul 05, 2011 | Sony Handycam DCR-HC24E Mini DV Digital...
I've got handycam Sony DCR-TRV140E and i looking for drivers to this one handycam on windows vista system.Come from i can get this one drivers.Help me please.
The USB streaming driver for the Camcorder is not available for Windows Vista OS from Sony at this point. Hence it is not possible to transfer videos using USB interface. You may use i.LINK or A/V interface to transfer videos from the Camcorder to the Computer which is running on Windows Vista Operating System.
i.LINK Cable.
i.LINK port.
It should now be possible to capture videos using a video capture software if the computer hardware and software are configured correctly.
Jun 27, 2011 | Sony Handycam DCR-TRV140E Digital...
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
How do i transfer my sony handycam ccd tr416
Use the link below to transfer video to your Computer using A/V cable and the Video Capture software.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C428275
Aug 07, 2009 | Sony Handycam CCD-TR416 Camcorder
Sony analogue Hi8 Handycam as a security camera
Hi!
You need to have things with you before you can proceed to use it as a security camera. As your's is a analog camera we will require a video capture card connected with your pc/laptop.
After you have one connect that with your pc and pTo get the video into your computer, you need a analogue to digital video capture card....otherwise, connect the camcorder to a CD or DVD player/recorder, and use the CD/DVD as a source for your video editing... Otherwise, you need a later model of SONY "Digital 8" digital camcorder which plays analogue tape, and with this your computer can capture the video via firewire
For details on how to record using a software and video capture card please look at this link---
Handycam as Security camera
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 06, 2009 | Sony Handycam CCD-TRV68 Camcorder
Sony handycam dcr pc350 video capture problem with vista
As per Sony Support, DCR-PC350 is compatible on Vista, however there is an update of picture package available at Sony Support.
Download update and check the camera file transfer operation.
Jan 16, 2009 | Sony Handycam DCR-PC350 Mini DV Digital...
How to save videos from sony handycam to my home pc
If I understand the user guide correctly, you can set the capture format in Preferences and have the captured video saved as MPEG1, there may be other options depending on what that version offers. If this is the only software you have to edit video, you must capture it first to have it saved to a folder of your choosing (usually set up in preferences). After that you should be able to use Windows Media Player or Quicktime to play back the file you captured. You can convert the MPEG1 files to another format if you want by using free software such as AVS Video Converter or other software.
Oct 15, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
No picture at all
CCD sensor problem ( that you can play back but have no image in capture mode is typical of this common problem ). Sony might do this repair free of charge because properly manufactured CCD sensor should last 10 years+ .
Sep 04, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
122 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
