Question about HP Officejet 5610 All-In-One InkJet Printer
HP Officejet 5610 All in One printer
I had this printing and then I ran out of ink and I put a new cartridge in it and now it will not print. I just bought it..gave $100.00 more than Office Max had them..Which made me mad in the beginning...I have a Dell computer which has been a problem from the beginning..it too is still under warrenty until Sept 16, 2007 I want to get his stuff fixed or new ones in their place
  • Anonymous Dec 11, 2007
    I have the same problem.. New ink cartridge in and it wont print, the pages come out blank. doesn't matter if I print, copy or receive a fax.
    What should I do?
  • 45 Answers
What happens if you make copy is it working or is there any error message on display and have u removed protective tape from new cartridge
Posted on Oct 04, 2007
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Why won't my printer print black with a new ink
see it this site your problem solved
http://cluetechnologies.com/index.php?topic=688.0
Jul 02, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer not printing, message appears saying cartridges dont fit.
Have you recently changed your cartridges? Try replacing them, if you haven't printed for a while the cartridges will dry up and you will not be able to print.
May 31, 2010 | HP Officejet 5610 All-In-One InkJet...
I just added new ink in my HP Officejet 5610. The
check expire date
your have clog printhead try cleaning from printer menu
and if it still not alligne s*ck the old ink from the cartridge and refill it with fresh ink
check here how
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Feb 14, 2010 | HP Officejet 5610 All-In-One InkJet...
My printer display says: "print cartridge problem [black] reefer to device documentation to troubleshoot." What do I do, I can;t get my printer to print. I just bought new ink, so the cartridge can't be...
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Troubleshooting a HP Officejet 5610 All-In-One InkJet Printer. Installed new ink cartridge but it's still acting like its out of ink ie, spotty printing. Suggestions?
50% or stronger isopropyl works well as a solvent, 91% dries very quickly. Try cleaning both the contact-film surface of the ink cartridge and the print-head (carriage, actually) in the printer with a lint-free cloth or swab and solvent (swabs reach to the carriage contacts better) CAREFULLY. Clean the print head on the cartridge itself by pressing straight on, not rubbing back and forth, with a lint-free cloth and solvent. Use the HP print head cleaner program first, then check alignment with HP's program, then print a test page. Is this not exactly what the help file on maintenance tells you?
Oct 23, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
How do you change the ink carterage in an hp officejet 5610v all-in-one?
Hello !
To change the ink cartridge(s) in your printer,
Open the print-carriage access door by pulling it forward.
The print carriage moves to the far right side of the HP All-in-One.
Remove the cartridge.
Take the new cartridge from the package.
Remove the strip from the cartridge without touching the metal back.
Insert the cartridge.
Hope this helps.
Oct 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Re change ink
With the printer on, open the door to the ink cartridges (on right front). The cartridges will move over.  Tip them out. Remove the bright colored (can't remember what color) loose strip from the print head on the new cartridge and put them in the same way they came out. They are numbered and so it's pretty hard to mess them up.
Sep 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
619 people viewed this question
Clive
Clive
