Question about Sony ICD-BP150 Digital Voice Recorder
Can I plug it into AC power?
I'm burning through batteries, even rechargeables, way too rapidly. Is there any way to plug this darn thing in? Sony is silent on the matter. It has a plug for "Plug In Power", but that apparently refers to the type of microphone, and not an AC Adapter. Thanks, Dave
  • 944 Answers
If you get hold of an AC adaptor that gives the same voltage as the batteries (total if more than one), you can then connect it to the first and last battery terminals, (correct polarity). If you want to make it more "professional" or convenient then a pieces of wooden dowel the same size as the batteries, with a metal nail for the positive end, thumbtack for the negative end with the wires from the adaptor wound round/soldered to the end terminals works well and can be easily taken out and swapped for batteries when you need to. Hope this helps, please ask again if you need more clarification.
Posted on Aug 19, 2007
SOURCE:
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Plugged in not charging issue
b4 you go to your computer, try to check first the both end of your ac power cord by using a tester (analog or digital) if their is a connectivity passing on it. if no indication then check or try to /smile the ac power current adaptor, if it smile burned then their is a particular resistor or capacitor inside was burned out and bring to your nearest electronic repair shop for a replacement of that specific electronic part.....if none of the above is the problem, your second thing to do is read the manual included of your pc and go to battery guidelines for you to check/review the features such as, maintenance, the number of charge, life span and the capability of your pc battery...then try to fully drain the power of the battery and recharge using your pc unit............P.S.,,,if your always using ac- power @ your home, just remove the battery of your PC when it's already full inorder to longer the life span and maintain the battery memory to the fullest. make it 101% drain and re-charge in the same ratio.pc @ home just
Aug 19, 2011 | HP Compaq Motherboard
Bought a x300 latitude dell laptop. Powers on with ac power adapter, but batteries will not charge even when left plugged in for 6 hours or more. Could it be a bad motherboard??
It could be a faulty battery or a faulty charging circuit.
Rechargeable batteries have a finite number of charge and recharge cycles. There capacity reduces with age until they reach a stage where they won't charge at all.
Oct 24, 2009 | Office Equipment & Supplies
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Oct 16, 2009 | Sony VAIO FRV37 Notebook
Power can't turn on?
its not motherboard problem its ram problem
Jun 18, 2009 | Sony VAIO PCG-V505CP Notebook
Frequent interrruptions
Initially, I would suspect the battery (even when plug to the AC). To confirm, pls try running without the battery and purely on AC adapter. Alternately, it could be a loose component internally such as the memory, LAN or WiFi card and in some models, video card. In my Toshiba, it turned out that the WiFi was consuming too much power that it discharges the battery rapidly and the charger was having a hard time coping up. My solution was to turnoff the built-in WiFi and install a D-Link USB.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Computers & Internet
BATTERY (Li Ion) NOT RECHARGING
in the case of my T23 laptop. when i plug in the ac adapter the battery will charge but when i turn on the power button. It won't boot and will shut off eventually. cant you help me with this
Nov 08, 2008 | IBM ThinkPad T23 2647 Notebook
Sony ccd-f55 Handycam
If it is a CCD-F555 the battery charger is also the AC Power adapter. There is a switch that states VTR...switch to it and plug into the camera and it should work. Have you had any other problems with your camera. I got mine in Japan when I was stationed over there and it will play back the tapes; however, it will not show the camera in the viewfinder. I know the lens is working because it will autofocus. I just can't see it. My email address is ds4190@excite.com
Dennis
Apr 26, 2008 | Sony Handycam CCD-F555 Camcorder
Sony ICD-BP150 Digital Voice Recorder Logo
97 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
