Question about D-Link AirPlus DI-614+ Wireless Router
Wired connections can't play RISK II w/wireless connections
I have 3 laptops using a wireless connection to my router and I have 2 wired connections. I have managed to connect up 3 wireless computers to play RISK II but when I try to connect with a wired connection the wirec connection can't see the game at all....
  • 12,061 Answers
This is because they are on differing addresses.. you may have to "Bridge" the network connections.. the Wifi is probably on 10.0.0.* and the Wired is on 192.168.0.* you need to make a "Connection" between the two so the can "See" each other. You will find how to do this in ya manual. Here is a link to help.. www.microsoft.com/technet/community/columns/cableguy/cg0102.mspx I "Googled" how to bridge wireless & wired networks router xp So if ya get stuck try a "Google" ... :)
Posted on Aug 20, 2007
Do you have to connect the router to the computer to use it
You have to be connected via either Wired or Wireless connection to use a router. You can use wireless exclusively, wired connection is not required, but often handy for troubleshooting connectivity issues. If you are using DSL or Cable modem, the modem is connected to the uplink port of the Router, then you either connect wired via port 1, 2, 3 or 4 (they are all the same) or a wireless connection (Default settings are unsecure wireless for most routers)
Jun 30, 2011 | Belkin F5D8236-4 Router
Belkin Play N600. Acer Vista laptop. Wifi only, laptop wifi connects then disconnects. With ethernet connected the wifi and ethernet shows connected, when unplugged, the wifi will disconnect also.
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 24, 2010 | Belkin Play N600 Wireless Dual Band Router...
When initially setup the router worked fine. However, after a computer crash and re-install, the desktop pc cannot find the router even though it is connected by Ethernet. Laptops will connect to the...
Dec 09, 2010 | Belkin Wireless Play Router (F7D4302)
I have internet connection but my laptop will not connect
Check your connections. 1. Wired: directly connected to the modem (not the router) If this works, the router is the issue. 2. Wired directly to the router If this works then wireless is the problem 3. Wireless Check Key for accuracy, Upper and lower case matters. Check that your router does not have MAC address restrictions 4. Clear the cache on the laptop IE. Use the Options menu to clear this.
Dec 12, 2009 | MSI U120-024US Notebook
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
NETGEAR wgr614 cable wireless router
have you tried to follow the manual chapter 3, page 3-1 ?
If you lost your manual you can find one here:
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
One of your computers can go online because its using a wired connection to the router, but the wireless clients cannot access the connection - is this right?
Then you only need to setup the wireless part in the router.
Mar 07, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Zyxel will not connect to my laptop wirelessly
Step 1 - If your laptop contains an ethernet port for a wired connection -- connect it to the router using a wire. Try to use the internet -- if it works we are assured the router to the internet is correct.
Question 1 - Please respond to this with the make and model of your laptop and if you have one the make and model of wireless adapter for use with the computer.
Question 2 - Was this router originally purchased new or used?
Question 3 - Has this router work wirirelessly with any other computer you know about?
Question 4 - Have you configured this router since you got it?
Question 5 - Have you had someone else configure this router since you got it?
Dec 07, 2007 | Zyxel Prestige P-330W Wireless Router...
I need to connect a real router with more ports to it 4-2 pcs
Connect the LAN port on the Barricade to the WAN port on your wireless router. The Barricade should be "plug-and-play",
i.e., no need to configure it. Similarly, the WAN port on the wireless-router is plug-and-play, so it should automatically get an IP-address from the Barricade.
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Then, start Internet Explorer, and connect to the web-server "inside" the router. Run the "Wired Network Setup Wizard", and then the "Wireless Network Setup Wizard". When you're done, then your "wireless" device(s) (iPod Touch, laptop, XBox360) should be able to make a wireless connection.
Note: no need for any CDs to "install" anything.
Sep 23, 2007 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
D-Link AirPlus DI-614+ Wireless Router Logo
171 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
