Question about Saeco Easy Espresso Machine
Saeco Easy - Chamber clogging with coffee
I've owned a Saeco Easy for 5 months with no problem at all. Recently I've had a problem similar to ones I've read on the site here. The advice from espressodoc was great - I pulled down the trap door and found coffee in the chamber, cleaned it out, things seemed to work again. However, after only two more coffees it jammed again, and when I checked the chamber was full of coffee again. Each time I clean it out it works again but I can't figure out why it's not clogging all the time. I've just recently switched to an oily bean - is it possible that the machine won't work well with all bean types? Thanks for the help. Mike
    Sergeant:
  • 279 Answers
After quite a bit of digging (not a lot of information out there on this), I found a handful of others who said that oily beans will cause this problem. Sorry I can't give you better news on that. If you do wish to try a new bean though, you might want to check out this site: http://killerbeans.com/site/home.html The satisfaction guarantee is legitimate, and this is the only place I know where you can actually find out the roast date of your order (though you have to ask, he's happy to let you know).
Posted on Aug 31, 2007
SOURCE:
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Red light showing when i go touse frother steam not consistent
For Saeco Vienna De Luxe Espresso MachineTeam De-Brewerz.com says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler. You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Oct 20, 2014 | Saeco Vienna De Luxe Espresso Machine
Saeco taleo grounds are very wet - almost fluid! this hase started recently when i changed my beans. i have changed the grind to course but with no effect. any ideas?
Try adjusting the amount of coffee and then the grind to finer. If there is not enough coffee in the chamber then it gets over extracted and you get a soupy puck at discharge, if the grind is too coarse, you might also get the same result. Think of your coffee grind as rocks and sand and that will give you a better feel for the proper setting for your machine.
Jan 29, 2010 | Saeco Talea Touch 14-Cup Coffee Maker
My saeco incanto doesnt dispense coffee any more only water comes out of the dispenser :( please helppppp ,it was working fine an hour ago then suddenly i start getting only water instead off coffee , P.S...
Check the coffee dregs are they wet? Or are they even there?
If there are no dregs then the grinder chamber is clogged and needs to be cleared out, remove the brew unit and you can gain access to the chamber on the left. Clean the chamber.
Jun 25, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Easy
I think I have the solution. The "thwok, thwok, thwok" noise is a solenoid opening and then slamming the trap door that dispenses the coffee. Mine had a similar problem.
Upon removing the top, I found that the solenoid, and further that the mount where it attaches to the plastic frame was broken. Basically, the little plastic fin that should hold the lower flange of the solenoid was sheared off. That left the solenoid free to move, and made it impossible to complete the action to move the dispenser trap door.
It looked like there was no easy way to replace that part of the plastic mount, so I epoxied and zip-tied the solenoid into place. It seemed to do the trick. I doubt it will last forever.
-tony
Oct 06, 2008 | Saeco Easy Espresso Machine
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Curious
Try to descale your machine, if there are calcium in the boiler then the coffee will have wrong temperature and tast bad.
Aug 06, 2008 | Saeco Aroma Espresso Machine
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco odea go
Try to use another brand and more dry coffee.
Apr 10, 2008 | Saeco Odea Go
Saeco Easy Espresso Machine Logo
70 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
