Question about Rockford Fosgate Punch 301S Car Audio Amplifier
Remote wire hook up
My punch amp is hooked up to the battery & is grounded.It does not power up so my question is does the remote wire go from the amp to the battery (Which does not have any juice when checked with a tester) or what. Thanks.
    Problem Solver:
  • 10 Answers
The Remote wire should connect to the remote turn on lead from you radio(most aftermarket radios use a blue and white or a blue wire for the remote turn on). This wire will send a 12v signal to the amp from the radio when the radio is turned on. You can disconnect the remote turn on lead from the amp and jump a wire from the terminal marked battery to the remote turn on terminal just to see if the amp powers up. Do not leave it this way however because your amp will not shut off and your battery will go dead.
Posted on Aug 19, 2007
SOURCE:
Crossfire vr2000d wont stop cutting out
Bad ground, possibility of some wires touching
Oct 25, 2017 | Crossfire VR2000D Car Audio Amplifier
I just bought a punch 500 a2 amp. i hook up my ground, then try to hook up the power cable and it sparks. my punch 250 was hooked up minutes prior to this so i know my wiring is good. what the heck is the...
The spark could be from the capacitors in the amplifier charging. Make sure the main fuse from your battery is still good and also check all the fuses on the amplifier. Verify all the wiring is correct and make sure none of the wires from inside the positive cable are poking out and touching the vehicle or amplifier chassis. If you have a 1k ohm resistor, you can put it in series with the amplifier power line to slowly charge the capacitors. You can do that by following the directions from the link below. After doing all that, remove the 1k resistor, hook it all up and try it again. If it still doesn't work, make sure your remote wire coming from the head unit has a voltage on it when the head unit is on. You can get a cheap volt meter from a hardware store or wal-mart.
http://www.ehow.com/how_7203337_charge-capacitor-car-stereo-system.html
May 21, 2011 | Rockford Fosgate Punch 500a2 Car Audio...
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Amp shut off has power and grond and remot but only my p550 shut off fuses are ok and all other amps are wourking
how many subs are you running on this amp, and how many ohms are they. if the are bridged, try hooking up stereo and see if the problem still occurs. make sure your scrape off all the paint where the amp is grounded to the frame which should be less than a few feet. i'd also recommend running at least a 4ga wire for both your power and ground.
Jan 30, 2011 | Rockford Fosgate Punch P550.2 2-Channel...
When hooking amp directly to battery, you hook battery hot cable and power hot cable then hooking ground cable up the ground cable becomes hot and pops the fuse
your amp is bad. you should have a 12v, ground, and remote wire. if these are hooked up correctly, your amp is more likely broken, and needs to be repaired or replaced.
Jan 30, 2011 | Car Audio & Video
401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
try hooking the remote wire to a rem wire on the back of stereo. post and let me know results
May 30, 2009 | Rockford Fosgate Punch 401S Car Audio...
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Amp
Make sure the amplifier is turning on. Remember ther is three wires that power the amp Battery constant, Ground which in a fiberglass boat run ground to battery not motor, Plus make sure the remote wire is hooked to power, generally it is switched power. But if the amp is not turning on temporarily hook remote and power together to battery and see if the amplifier turs on. Second be sure you have a good set of RCA cables hooking the radio to the amp. And finally check and make sure the gain is turned up on the amplifier.
Aug 31, 2006 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Rockford Fosgate Punch 301S Car Audio Amplifier Logo
938 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
