Question about iLO DVDR05 DVD Recorder
ILO DVDR05 makes high pitched squeal during recording
My iLO DVDR05 makes high pitched squeal during recording; it squeals for about one second and then stops for 1/2 second. It occurs in this sequence during the entire recording. It does not occur during playback. This recorder was given to me as a present; so it's either find a fix in this forum or throw it out. Any and all solutions are very welcome. Thank you!
  • 32 Answers
Usually a problem like this has to do with d.c. power sypply problems. Because "record" uses a different supply voltage and maybe "subcirckit" [not the same dc voltage that you use for playback, etc] If you know HOW to look inside and if you know how to take voltage\current readings...check ALL capitors,the diodes(misspelled?)Replace any that are "swolened", they are bad Other then that, take it to tech who if he is a crock he will overcharge, and if he is honest will repair for a fair price..... " Rotosa Ruck " [lots of luck]
Posted on Aug 20, 2007
SOURCE:
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Our water softener makes a high pitched squealing noise every 10 min. or so, and then quits for several hours only to start again during the night when we're trying to sleep. Our water softener repairman...
A softener will generally make a high pitch squeal when it is backwashing. This is generally the first cycle in most softeners. It may also do this during the final fast rinse cycle. The second brining cycle takes about an hour. That is why you may have a delay in the squeal. Also I have seen at times when a power surge can force the drive motor into a short backwash. Usually just a few minutes. It may help to put a surge surpressor at the water softener plug.
RJ
Aug 22, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Polariod FLM-3232 Screen Flicker & High Pitch Squeal
replace all the capacitors in the power supply
board.you will see the capacitors bulge out on the tops.change all of them with a higher
voltage.
Aug 08, 2009 | Polaroid FLM-3232 Television
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
ILO DVDr05
As long as the voltage rating is higher, not lower, it is fine, actually better, especially since this seems to be a fairly common problem, the capacitors used may not have a high enough rating to survive transients that may occur. As long as you are replacing them, I would use a higher rating, to make it more robust.
Nov 20, 2008 | iLO DVDR05 DVD Recorder
Ilo dvdr05 dvd burner
Do the discs play okay in other dvd players? If not, perhaps the unit is getting hot during recording? Mine has to have ample space around it in order to not mess up.
Sep 09, 2008 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
95 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
