Question about Necchi 3537 Mechanical Sewing Machine
Sewing machine problem
No problems until today. The fabric advances, needle goes up and down, but no stitches are made. Thread just stays on top of material.
  • 202 Answers
Not knowing what type of machine you have I just have to say there are three letters to remember... T-N-T. Thread, Needle, Tension. Since this is obviously not a tension problem you have to make sure the machine is threaded correctly. Incorrect threading will cause this as will the bobbin in upside down and turning the wrong way. Then there is the needle. Be sure it is inserted properly. My opinion is the needle is in wrong or the bobbin is turning the wrong way. Good Luck. Rick
Posted on Aug 22, 2007
How to sew Lycra on my necchi 522? I'm using a stretch needle. It goes up and down, fabric advances, but does not pick up bobbin thread - so no stitches!
Knit fabric sometimes plays a little havoc with machines. Be sure you are using a brand new needle. Also, ballpoint/jersey needles will usually work better with knit fabrics like t-shirt fabric. For very stretchy fabric like Lycra, you might want to try a Stretch Needle.
Schmetz Needles Needle Guide
Sewing Spandex Tips
If it still will not stitch, check your machine on regular woven fabric with a universal needle. Could be your machine is slightly out of time, especially if you have recently sewn over & hit a pin.
Oct 26, 2016 | Necchi Sewing Machines
How do I get it to sew?
was the presser foot lowered? check if the loop-taker is properly installed or seated.
Oct 03, 2015 | Brother XL2600I Sew Advance Sew Affordable...
Why isbobbin stitch on top weird how do i fix
sorry but the bottom stitch does not move but the top one does . if you want straight stitch the machine setting has to be changed to straight .
May 22, 2015 | Sewing Machines
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
Hand held sewing machine
I think you are saying no stitch is formed also referred to as the needle not catching thread. Below offers a variety of diagnoses and solutions which are straight forward.
Sewing Machine Needle Not Catching Thread
Below is general advice quoted from 6 common sewing machine problems solved:
Skipped stitches are usually due to a bad needle. The needle may have become damaged or bent by sewing material too thick for the needle, forcing material through the feed dog, or hitting a straight pin. If the problem seems to be consistently reoccurring, it may be due to forcing the fabric. Sewers should allow the feed dog to pull the fabric and only use their hands to guide the fabric through the feed. When sewing knitted fabrics, using a stretch needle can help prevent skipped stitches.
Below is a video showing how thread is hooked into a fabric:
Sewing Machine Anatomy How Stitch is Made
Jan 18, 2018 | Sewing Machines
Sewing a bunch of thread from the bottom, this stops the machine from actually sewing
Yes, it does. There are a couple of reasons the bobbin thread could be bunching up on the underside of the fabric. It could simply be that the machine needs cleaning. Take the bobbin assembly out, brush all the old lint out as best you can, reoil the machine once it's all clean, and make sure there aren't any little bits of thread caught in the bobbin assembly. Rethread the machine (carefully) and change the needle. This solves the problem usually--especially if the machine was sewing along fine and the problem develops suddenly. '
The other thing to check is your tension. It could be that the top tension is too loose. But different color thread in the top and in the bobbin, stitch a few inches (be sure to held the top and bobbin thread ends behind your needle as you start to stitch) and check. WIth the pressure foot down, adjust the tension, and stitch again. Keep stitching, checking, and adjusting until you see little if any bobbin thread on the top or top thread on the bobbin.
Another thing to reminder: use the appropriate thread and needle for the fabric you're sewing.
Let me know if this works, ok?
Jan 31, 2010 | Elna Sewing Machines
Cannot machine quilt without the thread breaking and/or shredding. I've change needle, thread type and size and tension on my fabric.
If the thread is shredding and breaking, there is an incompatibility of your needle, thread, and fabric. Could be old, bargain bin, or poor quality thread--does the thread have little "hairs" of thread lint sticking out of it--that's probably not good quality. Look for fresh, good quality thread. Try a brand new needle--a sharp if you are sewing woven fabric. Make sure the thread is not too big for the needle eye. Sometimes, a top-stitch needle or embroidery needle will work well on FMQ. (A top-stitch needle has a longer scarf which helps protect the thread during the multiple times the needle penetrates the fabric before the thread forms a stitch. Shredding means the thread is getting worn out before it forms a stitch. A piece of thread penetrates the fabric 10-20 times before it forms a stitch.) Could also be a snag somewhere that is damaging the thread.
Sewing Needle Troubleshooting Guide
SCHMETZ Household Needle Chart
Most FMQ instructions say the upper and bobbin tension should be the same, however, I find my machine works a bit better when the bobbin thread is just a little tighter than the upper thread. Then the bobbin thread does not "pop" up on the top of my fabric quite as much. It's probably something you will just need to experiment with in getting used to your machine.
P.S.--when threading your machine, make sure the Presser Foot is ALWAYS RAISED so the top thread will seat properly in the tension disk. Failure to do this will cause thread barfs (usually referred to as thread nests or bird nests) under your fabric. Also, before beginning your FMQ, ALWAYS PULL the bobbin thread to the top of the fabric, then hold both thread tails gently in your left hand while you slowly take the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Mar 01, 2017 | Brother Sewing Machines
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Necchi 3537 Mechanical Sewing Machine Logo
61 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
