Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If u have Digital Cam and you want to protect then don't touch the cam lans because if u touch it and try to clean them u scratch the cam lens cover..after do this the pic who u capture is not so good and the life of the Digital cam is too low ...so b careful about your cam lens and cover it very carefully...if u want to clean your cam lens then u use a cotton..because cotton is less harmful for cam lens as compare to another source ..Thanks..
Check the menu, many cameras allow you to enable photo protection, you may have some photos protected. You won't be able until that protection is removed.
To Unprotect go to MENU down on the lower left when ur looking at screen press menu while u have one of the protected pics up. Go to Protect folder-select-ok-hit W at top-ok
it is now unprotected and u can delete from here!
If the pictures are protected, see page 43 of this manual.
If the memory card is protected, look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Remove the card from the camera. There is a small slide tab on the card which shows a picture of a lock. Move the slide tab to the unlock position. If this doesn't fix it, replace the card.
This is a computer error.
Check images are there in the camera by looking at the review screen.
Then check you have not 'locked' the stick or 'protected' images
turn off the protected then try
