Question about HP iPAQ H5555 Pocket PC
IPAQ 5550 I WAS GIVING A IPAQ 5550, BY MY MATE WHO IS AWAY ON HOLIDAY IN IRAQ ,SO I CANNOT GET THE PASSWORD ....CAN ANYONE GUIDE ME THROUGH HOW I WOULD RESET IT..... I HAVE THE INSTALLATION DISC,WHEN I CONNECT TO ACTIVE SYNC IT ASKS FOR pASSWORD .
  • MURDY Aug 23, 2007
    THANK YOU FOR YOUR HELP,VERY MUCH APPRECIATED.
  • kaufmanelect Sep 03, 2008
    I did a hard reset, and still ask for a password
    Is there a defalt password?
Performing a Full Reset A full reset is sometimes referred to as a ?hard reset.? Perform a full reset when you want to clear all settings, programs, and data from RAM. A full reset deactivates the battery. The power button does not function until the battery is reactivated. CAUTION: If you perform a full reset, your iPAQ Pocket PC returns to its default settings and loses all information that is not recorded in ROM. To perform a full reset: 1. Press and hold Application Buttons 1 (Calendar) and 4 (iTask) on the front of the unit and, at the same time, use the stylus to press the Reset button on the bottom of your iPAQ Pocket PC. 2. Hold all buttons until the displayed Full PDF document can be found here: http://h20000.www2.hp.com/bc/docs/support/SupportManual/lpia8006/lpia8006.pdf
Posted on Aug 20, 2007
SOURCE:
IPAQ 5550 can I override the pin number?
Simple Solution:
Perform a hard reset and then attempt to login repeatedly (10x).
You will then be prompted if you wish to reset the pin entirely.
Good luck,
-AndyPants-
Jun 15, 2009 | HP iPAQ H4150 Pocket PC
How do i do a FULL RESET on my ipaq 5550
Hey,
instructions are here
http://geopocket.org/AngellHallAudC/ipaq_5550.htm
Let me know if you need anything else.
Thanks,
Ekse
Mar 02, 2009 | HP iPAQ H5550 Pocket PC
Hp ipaq 5550
To do a full reset, you hold the calendar and itask buttons (buttons 1 and 4) down at the same time, then insert the stylus into the little hole on the bottom and press gently. Hold all for 4 seconds. The screen should begin to fade. Now release all. If successful, you will not be able to start the machine by pressing the on button. You will have to reconnect to ac power to start it.
That is all there is to it.
Jan 24, 2009 | HP iPAQ H5550 Pocket PC
5550 not powering on
was the battery a exact replacement to the one you removed?
also do you have the power adaptor for it put the old battery back in and see if it will run off the adaptor with the old battery plugged in and then you know the issue is with the new battery and not the unit itself.
Sep 16, 2008 | HP iPAQ H5555 Pocket PC
Water Ingress
Place a piece of tape on the screen and lift gently to lift touch screen from pad and it should separate if dry.
Aug 26, 2008 | HP iPAQ H5550 Pocket PC
The HP ipaq 5550
Thats not a problem.. I have holidays and should not have a problem for livechat anytime and if you can just let me know in advance that would be enough..
Mar 09, 2008 | HP iPAQ H5455 Pocket PC
HP iPAQ RZ1710 Pocket PC freezes on pin entry!!
If still freeze after the resets, then try to do a Hard Reset.
With this way you will restore your device at the default condition.
Take care to remove any external memory from iPAQ before to this and also have it
full charged.
The bad of this....you will loose everything stored at the internal memory of iPAQ.
The good this...your iPAQ would be alive again ;-)
To to a Hard Reset press at the same time the reset button+calendar button+today button.
Jan 10, 2008 | HP iPAQ RZ1710 Pocket PC
WPA-PSK and AES
on my ipaq hx4700 , i'm only able to use wpa-psk tkip, no aes option. not sure if any difference on 5550.
Sep 14, 2005 | HP iPAQ H5550 Pocket PC
PAQ 5550 and MMC 4.x (Plus)
so MMC cards are the older version of SD cards. Ipaqs support the fast SD cards and all sizes up to the max.
Sep 08, 2005 | HP iPAQ H5555 Pocket PC
HP iPAQ H5555 Pocket PC Logo
712 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
