GE Appliances 30" Trivection Built-in Single Wall Oven - Stainless Steel - Jt93 Logo
Anonymous Posted on Jun 09, 2013
Control panel not responding to touch -- NOT in locked mode!
I don't know what happened. Suddenly the interior light was on in the oven and the timer was counting down from 60 seconds. The control pad was not responding. When the timer went off, the only way I could get it to stop was putting it into "LOCKED" mode by pressing numbers 7 & 8 together. When I unlocked the keypad, the keypad is still not responding. I can't even turn off the interior light. ???
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Jun 10, 2013
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4479446
Points
21747
Sounds like you have a shorting membrane keypad, or there any be moisture or grease in the controls.
To remove the controller to check for grease and moisture, see the video here.
We would need your full model number from the tag in the cooking cavity or elsewhere on the oven to help you further, and our advice is free.
Please post a new help request with the full model number.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 09, 2006
SOURCE: can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Anonymous
  • 126 Answers
  • Posted on Apr 25, 2009
SOURCE: Microwave is locked. It says "Keypad touch locked"
Hold lock button for a few seconds and it should return to normal
Anonymous
  • 11896 Answers
  • Posted on Jul 25, 2010
SOURCE: Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Anonymous
  • Posted on Sep 21, 2010
SOURCE: Control panel is locked.
Pres the "Clear/off" button and hold it down for six seconds. The panel will unlock.
zappanut
ZappaNut
  • 960 Answers
  • Posted on Mar 23, 2013
SOURCE: GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
1helpful
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Maytag microwave keypad
see this causes and fix it. God bless you
A small blinking light on the left upper corner of panel after a power outage and I can't do any command. The interior lights don't even come on when opening door. I already reset the breaker
Unplug the microwave oven for 10 minutes in a attempt to reset the microprocessor ic, press and hold the start button for the same time and release. Now plug everything back in hopes it will restart, if no change! the keypad control board will need to be replaced along with other unknown parts, due to the nature of damage far cheaper to replace.
2helpful
Touch screen displays is lit up , but will not respond by touching any of the promts. I have unpluged the unit hopeing to reset no change. unit was working fine the day before.
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Amana rfs12sw2a....1200watt The soft touch buttons don't respond except for number 6....
Sounds like a bad control board. First just check and make sure all of your connectors are in tight. Part numbers for the control board is 53001806 you could have a bad touch panel. rare and not typical but can happen part number for that is 53002019. I would probably buy both of those parts plug in the new panel into the existing control board and see of everything works. if so replace the touch panel and send the control board back. If it still does not work then swap the control board and send the touch panel back. hope that helps
1helpful
2answers
I have a two year old GE JVM1540 Over the oven microwave. For some reason the keypad does not respond to any touch. It just has the display panel scrolls press start but doesn't allow any action.
These units are known for this problem. You cook on stove and stream gets into keypad causing keypad not to respond anymore. The good news is keypad can be replaced, the bad news is it will happen again and the keypad costs around $125. GE will not admit to any problem, but I see this problem alot. You can get a new keypad at appliancepartspros.com
2helpful
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
1helpful
14 month old LG Microwave. The control panel is
Very common , You need to replace the switch membrain , this is the entire touch pad , they are not to much $ , and you should find it easy online.
Phil
1helpful
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
