Question about AEG 23 in. Favorit 86070Vi Built-In Dishwasher
AEG dishwasher not heating
I have a favorit 86070, which is running but does not heat up. Is this likely to be a heater element failure or PCB? What is the easiest diagnostic sequence?
  • 3 Answers
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Posted on Nov 09, 2008
  • 641 Answers
The easiest way to find it out, is to open dishwasher's rear panel and follow the next steps: -Check whether you have 115/220V on the heating element tags. -If you can read 115/220V on its tags, you should replace the element. -In case you can't read any voltage on its tags, check with a multi-meter for the thermostat's resistance. -If you can't read any resistance, you should replace the thermostat. - In case the thermostat is OK, your problem is with the PCB. Good luck !
Posted on Aug 19, 2007
AEG F60873 temperature problems.
The problem when the dishwasher does not heat is failure which requires to remove the qualified personnel and therefore error code is not shown on the display but it is visible in the service mode.
Possible error causes:
faulty heating element
wiring between heating element and PCB
PCB (printed circuit board)
Dado
Aug 24, 2014 | AEG Dishwashers
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
The dishwasher will not heat up what could be the problem
heatman101
Nov 23, 2010 | AEG 24 in. Favorit 40850 Free-standing...
My dishwasher has stopped heating the water and is washing cold with obvious poor results. Is it a heater matrix problem or something like that? It is a Tricity BendixDH200
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 07, 2010 | AEG 24 in. Favorit 40850 Free-standing...
AEG Favorit 40650 water heater not working. How do I check if it is the heater element failure or the printed circuit board control unit
Check the element by using an Ohm meter. You should get an ohm reading if the element is OK. If the element is open circuit you would get an infinity reading. Just note that "newer" machines do not use the traditional heating elements but do have a (Inductive heater) coupled in line with the hose feeding the top spray arm of the washer. This unit must be cheched by a dealer as a DIY will have dificullty checking it.
Oct 21, 2009 | AEG 24 in. Favorit 40650 Free-Standing...
AEG Dishwasher 54850 not heating up the water is no getting hot
This could be the electrical element (some use the old traditional element and some (later models) use inductive heater coupled in line with the hose feeding the top sprayer arm. A test with an Ohm meter should indicate if the element is open circuit.
Aug 02, 2009 | AEG 18 in. Favorit F54850 Slim-Line...
Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Jun 14, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
Water not heating. Element replaced with new but still no joy.
The water is heated via a "inductive heater" and not the usual heating elements. This heating device is at the bottom back of the dishwasher and is a cyliderical +/- 15 cm long metal tube. It can easly be removed by the wire clamps at each end. It does have electrical push on connector that just plugs out. If the electrical connections are good I suggest you replace it with a new one (if you can get one).
Mar 23, 2009 | AEG 24 in. Favorit 40660i Built-in...
AEG 23 in. Favorit 86070Vi Built-In Dishwasher Logo
1,376 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
