The power went out the other day and now the keypad does not work properly. For instance when you try to reset the clock the numbers on the keypad do not work, as well as when you try to enter a baking temp.
I can't promise results, but you might try my solution at the following link. It has helped over 1100 folks with a similar problem: http://fp1.centurytel.net/Powerman/Dreaded F7 Problem.pdf Let me know if it works for you too. You can email me at the following link: [email protected]
Mine has done the same thing. I had been shutting off the circuit breaker and that works for a while. It was under warranty so I had the tech replace the microprocessor board. He had seen issues like this in the past. Now, 8 months later it is doing it again. It locks up the panel so you do not have any control of anything. It seems to happen when baking at high temps i.e. 450 and above. Since it is still under warranty I will have the microprocessor replaced again. I believe they may have design issues with thier processor or heat related issues that could be causing this problem.
Link should be activated
Dacor range with similar problem. The key pad won't work. only the oven light goes on and off nothing else.
none of the keys will work - SA6 remains on the display - stovetop works fine.
Yes, I also have a ge profile and now some of the keypad numbers don't work..specifically as far as I can tell...3 and 0/
The link above no longer works
