Back to:
Tags:
Trisonic TS-1666RFS Remote Control
Trisonic ts-rc488 (by 12 users)
posted by dogg99999 on Aug 19, 2007
i need all the codes for the remote
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
11 Other Users Have The Same Problem
Comment by esmie07, posted on Aug 24, 2008
I need the codes to program control to my sanyo tv.... please help..
Comment by SCREWZ, posted on Mar 31, 2008
does anybody know how to automatically search for the code...i know you press channel up or something until it reacts but i forgot if that was the correct method...
Comment by angel72, posted on Mar 20, 2008
need codes 4 rc444 and a sanyo tv
Comment by Guest, posted on Feb 28, 2008
My sister gave me Trisonic remote and I need the remote control codes for it. I need to get the codes ASAP
Comment by Aghuni, posted on Feb 20, 2008
I have Trisonic TS-RC488 universal remote controle and looking for "code list" or just a "code" for Aiwa Multi System Converter Digital VCR.
Your cooperation will be appreciated.
Best Solution
posted on Jul 28, 2008
FixYa! (100)
JAC1NJ
Rank:Master Master
Rating: 98%, 7 votes
OK EVERYONE I FOUND ALL YOUR ANSWERS , IM JOHN FROM NEW JERSEY JAC1NJ@AOL.COM , FOR THE TRISONIC UNIVERSAL REMOTE CONTROL , TC-RC488 AND MAYBE OTHERS , INSTEAD OF THE CODES THIS IS EASIER,TURN ON THE TV OR VCR ETC. FOR THE POWER MUST BE ON WHILE DOING THIS PROCEDURE , PRESS THE YELLOW SET UP BUTTON AND THE DEVICE KEY U WANT SUCH AS TV1 OR VCR1 AND HOLD THEM BOTH DOWN UNTIL THE RED LIGHT ON UR REMOTE STAYS ON THEN IMMEDIATELY AFTER HIT THE YELLOW SETUP BUTTON AGAIN UNTIL UR RED LIGHT STARTS BLINKING THEN POINT THE REMOTE AT YOUR TV OR VCR AND KEEP HITTING THE RED POWER BUTTON AS THEN YOUR REMOTE IS TRYING TO FIND A CODE AND WILL EVENTUALLY FIND A CODE , AND YOUR TV OR VCR WILL SHUT OFF , THEN THE RED LIGHT WILL BLINK LET IT BLINK UNTIL IT GOES TOTALLY OFF, THEN HIT THE POWER BUTTON AND YOUR REMOTE SHOULD WORK , SOMETIMES YOU HAVE TO HIT THE DEVICE KEY AND YELLOW SETUP KEY SEPARTELY AND THEN THE RED POWER BUTTON, I CALLED TRISONIC AND ACTUALLY HE HELPED ME AND I HELPED HIM , HE SAID I SHOULD WORK FOR TRISONIC , THIS IS A QUICK SEARCH , NOT REQUIRING ANY CODE NUMBERS, HOPE I HELPED YOU ALL SINCERELY , JOHN A.CLINE , CHECK OUT MY LIST OF LYRIC BOOKS AND MUSIC AT WORDCLAY.COM BYE!!!!!!!!!!!!!!!!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on trisonic ts-rc488:
I don't want to Accept this solution
Solution #2
posted on Jan 20, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
same problem
Thank You!
Solution #3
posted on Jan 09, 2008
Thanks for Trying (70)
MC Bun
Rating: 85%, 8 votes
I have found the answer. Call Trisonic toll free at 1-800-TRISONIC. I am sure the operate on a Mon-Fri basis probably 9am-5pm. It is the only way to get your codes I searched the internet for 2 hours and finally called TRISONIC. They were very helpful. In addition, the support technician I spoke with informed me that there are no codes available on the web. When you get your code you will need to push and hold the SET button first, then push your device button (TV, DVD, etc)as you continue to hold the SET button. I red light will appear on the front of your remote and it will remain on until your enter your device code. Enter your code and hit the power button to test your device.
This is the best and only way to get your Universal remote code. It saves you from having to buy another remote or spend any other money.
Thank You!
Can you Help with these Remote Controls problems?
Remote Controls
i lost my instruction manual and i need to get the tv code...
Remote Controls
Have a Toshiba CT-847 remote that came w/my TV I bought a...
Remote Controls
I need to download a manual for ge univ remote rc24918-d
your question is answered in my post
i lost my book for my trisonic also , and i have a sony tv...
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 06, 2008
My remote says Trisonic TS-RC444. I have a Toshiba 27" TV in my bedroom. I dropped the remote and now it worn work. I've replaced the two AAA batteries to no avail...I cannot get the remote to work no matter what buttons I push. I was thinking when I dropped it, did I press something I shouldn't have? I thought by just setting it up again from the begininging I'd be ok. Does anyone know the remote access codes for a toshibya tv? Thank you in advance.
Comment by Guest, posted on Dec 28, 2007
I need codes and how to program a trisonic ts-rc488 remote control. thanks Lisa
I need code and how to program a trisonic ts-rc488 remote control for an emerson tv. thanks Lisa
Comment by Guest, posted on Nov 07, 2007
i need all the codes for ts-rc444
Loading problems.
Repair Service
Find Remote Control Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
