I have a bissell bagless easy vac. When I vacuum the debris keeps getting stuck in the hose (also going into the filter area and the apparatus above the cannister with none of it going into the cannister. I have made sure the cannister is properly placed and the lock is pushed in all the way.
I have an electrolux epic series 2500 SR that is in pieces and I need to put it back together, I...
(More)
I have an electrolux epic series 2500 SR that is in pieces and I need to put it back together, I need to get a diagram to make sure it goes together correctly.
I have a bissell easyvac bagless. My son threw away my manual. I emptied it once and I can't get it...
(More)
I have a bissell easyvac bagless. My son threw away my manual. I emptied it once and I can't get it to work right again. I think it just needs to seel correctly, but I can't tell how to with out a manual. thank you Jeanel
I jsut bough the easy vac and it worked beautifully. I noticed the hose was clogged so I cleaned it...
(More)
I jsut bough the easy vac and it worked beautifully. I noticed the hose was clogged so I cleaned it and the canister. The vacuum is STILL not picking up and I've only used it once. HELP!
