Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell 7920e It work help
  • 48 Answers
Need more info
Posted on Nov 18, 2007
Bissell Proheat model 7901-1 is there diagram of
I have pasted a link to the Bissell ProHeat series carpet extractor repair guide below. This guide is like my Bible when I'm working on these machines, and is EXTREMELY helpful on explaining how, and where hoses and parts go, and possible explanations of problems, and how to fix them.
I hope that this information is helpful to you, it sure is to me. If you did find this helpful, please be so kind and vote my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair. This is what really keeps repair professionals like myself keep coming back and giving free repair advice, we greatly appreciate when people acknowledge our work here. Thank you ahead of time.
Bissell ProHeat Repair Manual
Thank you again,
Chris J.
GoVacuum.com
Apr 10, 2010 | Bissell 7901-R Clearview Proheat Plus...
Have lost my instruction manual for my bissell PROHEAT PRO-TECH 7920E pLEASE CAN YOU HELP ME J Mills
Bissell has online USER Guides... for your model
CLICK HERE you can click on the user guide under your model to download a fresh pdf copy
Happy Cleaning!
Dec 05, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell easyvac 3108.No suction.Changed filter/cup.Brush working fine.
I had the same problem, ended up I had to clean out the hose for the accessories...I found out how to do it by looking at the troubleshooting section of my owner's manual online at bissell.com. (Just type easy vac under troubleshooting and choose the instruction manual based on your model number). If none of these things work, you can always contact bissell at 1-800-237-7691. hope this helps!!
May 09, 2009 | Bissell 3108 EasyVac Powerbrush Upright...
Fit a pump to Bissell proheat 7920e
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wtqy
Jan 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I fit new diverta..
Usually this can go one of two ways, very easily, or absolutely a pain. You will need needle nose pliers, and patience. When I am in the shop working on these machines, it's always a matter of not getting frustrated, and using eccessive force.
If there is a coil spring you will want to pull that back gently, and place the arm back into place, always be gentle and patient. Then you may have to use a flat head screw driver to push the arm into final position.. again.. be patient, and gentle... this is all plastic except for the spring of course.
I hope this helps.
Dec 09, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Floor spray not working
my bissel carpet cleaner is working apart from it will not pass any water ?? help
Sep 14, 2008 | Bissell Vacuums
Cannot get machine to disperse any water or solution
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just refasten it down.
Apr 18, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
Jul 15, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
130 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
