I have a bissell bagless easy vac. When I vacuum the debris keeps getting stuck in the hose followed by the filter and the apparatus on the top of the vacuum with none of it going into the cannister. I have made sure that the cannister is correctly placed and the lock is pushed in all the way.
Check that the filters are completely clean. If there are clogged they would have to be washed and then dried to room temp (or a low temp tumble dryer, put the filters into a pillow case with a towel and install into the machine) Tip the bissell backwards to make sure the bottom bin is pushed and locked all the way in. Only when the two seals meet will you know that the bin has locked in properly. Unhook by prising the main hose at the back off to check for clogs as well as the main hose at the bottom and the main dust channel at the sole plate where the roller bar is. You may have to remove the bottom plate to check for any obstructions behind the brush bar.
I have the Easy vac myself. Its not an Easy machine to maintain when it gets clogged!
Was this helpful?
Yes
No
Popular Solutions for Bissell 3102-0 EasyVac Upright
I have a bissell easyvac bagless. My son threw away my manual. I emptied it once and I can't get it...
(More)
I have a bissell easyvac bagless. My son threw away my manual. I emptied it once and I can't get it to work right again. I think it just needs to seel correctly, but I can't tell how to with out a manual. thank you Jeanel
I have a bissell bagless easy vac. When I vacuum the debris keeps getting stuck in the hose (also...
(More)
I have a bissell bagless easy vac. When I vacuum the debris keeps getting stuck in the hose (also going into the filter area and the apparatus above the cannister with none of it going into the cannister. I have made sure the cannister is properly placed and the lock is pushed in all the way.
I jsut bough the easy vac and it worked beautifully. I noticed the hose was clogged so I cleaned it...
(More)
I jsut bough the easy vac and it worked beautifully. I noticed the hose was clogged so I cleaned it and the canister. The vacuum is STILL not picking up and I've only used it once. HELP!
