Question about LG VX8100 Cellular Phone
Text messaging Neither the manual or CD shows you how to enter the letters you want. Eg. How do I enter the letter "h"? If I press the key that it's on I get "g"
Push the button until you get the letter you want. For example: you want h, push 4, then push 4 again. The first push gives for g, the second one will give you g. If you want "i" push 4 again. You must pause inbetween the pushes but only for a second.
Posted on Aug 20, 2007
SOURCE:
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
Apr 04, 2011 | Motorola Mobility RAZR V3
Unable to format 16 gb transcen d
Hi friend first install ur Transcend and Logoff yours system now login again, click on start--> run ---> write command in text box cmd and then press enter, Now write coomand step by step
1) cd\ press enter
2) c:/> format drive letter (eg. D: E: F:G: etc) press enter
3) read care fully message and press y
Now yours device formatted
Jul 28, 2010 | Transcend (589307) Media
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
How do I type capital letters when I text message? I have abc1, abc2, 123, @%, but don't know how to add caps to my text sentences (other than the first letter of each sentence). Thanks!
Depends upon the set but usually this could be done bay pressing the hash key(#) OR the star(*) key.
also try keep pressing these keys.
If helpful, kindly do Rate!
Regards,
Waqar.
Jul 17, 2009 | Motorola Mobility RAZR V3
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    Disconnected battey, new battery, no aux
    Common Kenwood Security Codes
    Many Kenwood radios are configured with the same security codes:
    KCAR - This seems to be a "backdoor" to some Kenwood models.
    3051 - This is the security code which is printed in the manual of many Kenwood models.
    1234 - This is a security code commonly chosen by Kenwood owners.
    Entering Your Kenwood Security Code
    If the car battery fails or is disconnected, the Kenwood will ask for the security code.
    The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
    Type 1
    During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
    Enter the security code using your Kenwood remote.
    Type 2
    Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
    Type 3: Model# DPX-4020 and DPX-4030
    Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
    Entering Letters on your Kenwood Remote
    To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
    To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
    Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
    The key sequence to enter the security code KCAR is:
    5
    5
    Track Up
    Track Up
    Track Up
    7
    7
    Track Up
    Your Kenwood should then enter tuner mode.
    A Security Code Bug in some Kenwoods
    There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
    In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
    Jun 09, 2009 | Kenwood KDC-MP2035 CD Player
    I am locked out of my KDC-MP8017 CD player. How
    Type 1
    Type 2
    5
    5
    Track Up
    Track Up
    Track Up
    7
    7
    Track Up
    Jun 05, 2009 | Kenwood KDC-MP8017 CD Player
    Eurovox codes we don't know how to input them
    Hi, I dont have this box, but found this on another site, hope it helps, and its what you are after, if it is, and you need keys, let me know, good luck.
    GOTO MENU PRESS OK ON CHANNEL SETTINGS THEN KEY 1968 TWICE
    THEN ENTER YOUR RIGHT KEY TILL YOU GET NAGRAVISION
    CHOOSE YOUR PROVIDER PRESS OK
    GO DOWN TO YOUR 00 KEY
    USE YOUR RIGHT LEFT KEY TO ENTER THE RIGHT ONE
    THEN PRESS OK TO GOTO THE NEX ONE
    SAVE ON EACH KEY (00 AND 01)
    OR
    PRESS MENU - THEN PRESS THE YELLOW TEXT BUTTON (BOTTOM RIGHT).
    PLEASE TAKE NOTE OF THE BELOW:
    TO ENTER LETTER A = PRESS TV
    TO ENTER LETTER B = PRESS RADIO
    TO ENTER LETTER C = PRESS P-
    TO ENTER LETTER D = PRESS P+
    TO ENTER LETTER E = PRESS INFO
    TO ENTER LETTER F = PRESS RECALL
    TO ENTER 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 = PRESS THE NUMBER BUTTONS ON THE REMOTE CONTROL.
    ENTER THE PROVIDER & KEYS FOR YOUR AREA & PRESS THE OK BUTTON ( press 4 secs ) TO SAVE. THIS WILL BRING THE CHANNELS BACK TEMPORARILY WHILST A NEW SOFTWARE IS BEING RELEASED.
    IF YOU ARE UNSURE WHAT AREA YOU ARE IN, JUST ENTER ALL 3 SETS OF KEYS ONE BY ONE.
    E.G. ENTER CW KEYS THEN PRESS OK TO SAVE, THEN ENTER THE NTL KEYS THEN PRESS OK( press 4 secs ) TO SAVE & FINALLY ENTER TW KEYS THEN PRESS OK TO SAVE.
    AFTER THIS HAS BEEN DONE, YOU SIMPLY EXIT OUT OF THE MENU & ALL THE CHANNELS WILL START WORKING AGAIN.
    Feb 01, 2009 | StarTech.com StarView SV211K 2-port KVM...
    Motokrzr K1
    your phone's text entry mode is currently set to 'predictive text' which means the phone is trying to 'guess' the word that you want. Teenagers find this easy to use and fast, but I, like you, absolutely hate it.
    This mode is easily changed. When you start to write a text message, before entering any text press the 'hash' key (bottom right) sequentially until the top left of your display title bar shows 'Abc2' this means your phone is now in ordinary text entry mode.
    You can also change the case (capitals etc) by sequentially pressing the 0 button (bottom centre).
    Hope this helps
    Aug 12, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
    LG VX8100 Cellular Phone Logo
    61 people viewed this question
    Top LG Cell Phones Experts
    George Etukudo
    George Etukudo
    Sheldon Dedek
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
