Could you help me with an unlock code and procedeure for a Samsung R225M?
My IMEI is: 01026500046632/3
Carrier: T-Mobile
Country: USA
Thank you very much for your help.
[email protected]
I have two Samsung R225M's. IMEI's are 010096/00/090649/1 and 010286/00/407044/0. Can you help me unlock? [email protected] Thanks in advance.
Try the following codes
*2767*3855# full reset
*2767*2878# custom reset
*2767*927#
you need to take the sim card out from the phone and on the same part where you can write in 911 instead write the codes there
Okay, in that case this is a network lock and you need to use a unlocking service.
Add a Commhello my friend im from dominican republic, my name is anyelo I want to unlock my samsung R225, can you help me, God bless you the imel is: 01009608113513/5 help please ..........ent
I've used a company called http://unlockdata.co.uk, they unlock all sorts of phones and they are really cheap.
Hie
If you are trying to use a SIM card in your phone and getting a message like
"Enter Subsidy Code", "Incorrect SIM Card", "SIM not
provisioned" or similar messages, then you need an unlock code for your
mobile phone. You may contact to your carrier provider Samsung Star GT-S5233 Unlock Code they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with an networks worldwide without sticking to one network only. You may check Samsung Unlock Code site, they will
provide you an accurate code fast with easy to follow instructions on how to unlock your phone for the lowest price.
Hope it helps.
Thanks.
Reset codes didn't work. To be clear, the phone should be turned on with the sim card out, the codes should be punched in, the phone turns itself off, and then I should turn the phone back on with the sim card in. Tried this and still got the message "wrong sim card"
Can you suggest a good network unlock service?
