Question about EnGenius EOC-3220 (EOC3220)
Cannot browse to 192.168.1.1
I've followed all the instructions to the letter for setting the TPU address, and tried changing various setting all over the place but my browser always times out when looking for this address. The device is mounted and pointed at a emitter, and my network connection appears good, I just can't get into the EOC-3220 control screen.
  • 6 more comments
  • Mantar Aug 23, 2007
    Okay when not hooked up to the network cable I got four "Destination host unreachable" messages. When I hook up the cable I get four "Request timed out" messages. I don't know if it's relevant but when I just tried to duplicate it on my laptop I go four "Request time out" messages and only by disabling my wireless connection did I go back to unreachable.
    In answer to the second question, yes the wireless spot I have the device aimed at definitely works, that's what I'm using now. It's a MetroFi emitter in Portland Oregon three blocks from my house. By walking over here with my laptop I can pick it up fine. However until I get my eoc-3220 programmed to pick it up I have no internet connection at the house, so can't use it to get live help to fix the problem. Catch-22
  • Mantar Aug 26, 2007
    Weekend is finally here and I have time to work on it. Spent another $27.00 on a Crossover network cable and still am left with nothing but an expensive and not particularly attractive wall ornament. There is absolutely no difference in how it acts with that cable or regular network ethernet cables.
    I had purchased a wireless router intending to install that once I had the antenna tuned correctly. I've tried going though that as well as both Laptop and PC. I did get through once briefly so I'm still thinking it's the "stuck in hazy state" problem.
    I might have to suck it up and pay someone to hook this thing up for me.
  • Mantar Sep 03, 2007
    I JUST GOT IT FIXED! I'm using it now. I'm not sure if it was a "hazy state" or bad IP address but a reset worked. I contacted the recommended installation tech company, but they appeared to be too busy to call me back in a timely manner. However he did confirm that the reset required a Null Modem cable and that the port for it was hidden under a panel next to the network port.
    I found a null modem cable schematic online, made a couple trips to radio shack for supplies, and built my own null modem cable using a 20 foot coil of rainbow wire and two female 9 pin D-Sub connectors. It worked like a charm. I simply hooked the device to my serial port and did a flash reset/reboot from the huper terminal. When I hung it back up and found 192.168.1.1 first try. Thanks for you help and concern. Now I just have to get my wireless router working.
  • Gnidin Oleg Jan 04, 2008
    Sorry? can you give me your schema of null-modem cable, cause i have such problem, but standart cable don`t work
    sorry? can you give me your schema for null-modem cable, cause i have such problem, but standart cable doesn`t work
  • pinastro Feb 23, 2008
    Hi all.
    I'm having the same problem: can't browse to 192.168.1.1.
    I tried to reset to factory default by a nullmodem cable with the same result.
    The network is configured right.
    If I try to connect via wireless I see the SSID: 802.11g but it's impossible ti surf anyway.
    I tryed RTLAPConf.exe tool that discover IP looking the MAC address but can't find any device.
    I think that the web server inside the system is out.
    When I try to connect via hyper terminal ( null modem cable) I can reach the linux sh ( shell) were it's possible to send some commands ( like flash reset, ifconfig... ... )
    Maybe It's possible to re-flash the firmware by null modem cable on hyper terminal... I don't know.
    Please help me.
    Thank YOu in advance and sorry for my bad english.
    Giuseppe
  • Anonymous Mar 24, 2008
    What was the Null modem config used??
  • Mantar Mar 27, 2008
    DB-9 connector on one end,
    DB-25 on the other end
    DB-9 connectors on both ends
    Here is the Null modem cable schematic if someone needs it. Probably easier to buy one online, but I couldn't find one in town. The DB9 connection is beneath a plate. Since resetting it the first time I've had no problem with the antennae. Had software problems with Metro-Fi's new Side Guide add on, but managed to live with it,
TRY 192.168.1.254 IT WORK FINE FOR ME, AFTER ACCESS I RELOAD A NEW FIRMWARE, AND NOW IS 100% WORKING
Posted on Mar 27, 2008
This isn't a solution, but I couldn't figure out how to respond. Yes I was able to get on at one point, breifly but lost it soon afterwards. I wouldn't know how to ping even if I knew what command line you are talking about. My best guess if I had to pick from your suggestion is #6 because I did reach it at one point and I've tried with two different computers laptop and PC with same results. I am using the bridge that came with it. I found a method online for resetting the eoc-3220 back to default settings, but it requires a Null modem cable which I don't have. I've been stymied and am currently in the middle of working a string of 12 hour shifts with limited internet access so won't have time to look at the problem again until the weekend.
Posted on Aug 22, 2007
    Scholar:
  • 76 Answers
Have you EVER been able to access the control screen on this network? Can you ping the device from the command line? Did you try to telnet to the device? Without getting into a troubleshooting scenario on my first question, the possible problems are: 1)The device's IP is conflicting with another network device. 2)The device's internal subnet mask is incorrect (most likely it is 255.255.255.0, though) 3)Your subnet mask is not matching the devices. 4)The device is at another IP address instead of 192.168.1.1 (don't laugh and don't trust the documentation, been there, done that) 5) The device reset and defaulted back to factory IP. 6)The device is in a hazy electrical state where it needs a hardware reset. 7)You are trying to connect to it without a switch between it and your computer. 8)The device needs a cross-over cable to connect to your computer directly. Since each one of these items could be the cause, you will have to check and discard them one by one. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
  • 5 more comments
  • Stevie Wonderboy Aug 19, 2007
    Lest anyone think there are only 8 reasons for this problem, Of course there are other reasons, but hey..it's a start.
    ZT3000
  • Stevie Wonderboy Aug 22, 2007
    First, find out which IP address you placed the device on.
    If you didn't change it's default IP address, then disconnect the device so it is NOT connected to any network at all and it has NO power (essential step)!
    Then go to a command line and type:
    ping 192.168.1.1
    Hit Enter
    If you get 4 ping responses, then the problem is:
    There's already a device in your network at the 192.168.1.1 address and since this device sits at 192.168.1.1 from the factory, there is an IP conflict between the two.
    If you get 4 time-outs, then come back here and let me know here.
    Thanks.
    ZT3000
    Another question:
    Do you see any wireless indication, on your desktop or laptop, that this wireless device is even working?
    And if you see an indication that it is working, can you reliably connect to it?
    (of course, not to the control screen).
    ZT3000
  • Stevie Wonderboy Aug 23, 2007
    Mantar,
    Based on your Aug 23 response, I'm now pretty sure what the problem is (since we ruled out conflicting IP addresses).
    Some devices have an MDI/MDI-X RJ45 port and some don't.
    An RJ45 MDI/MDI-X port is an autosensing port that can use either a straight pinnned RJ-45 cable or a cross-over pinned RJ-45 cable in order to communicate to the device.
    Of course this device's manual doesn't tell you but...
    in order to connect to this device directly from your laptop, you will have to use a cross-over cable (not a null-modem cable).
    If you connect the EOC-3220, first, to a switch or router then use a straight thru RJ45 cable (actually it doesn't mnatter which cable you use, since the switch/router understands this).
    Straight thru RJ45 cable is the type normally sold at computer stores and office supply stores. If it doesn't say "Cross-Over", then it isn't.
    So...
    Either buy a "cross-over" cable or use two straight thru (normal) cables.
    One straight-thru cable goes between the EOC-3220 and your switch (or router), the other straight-thru cable goes between your desktop/laptop and the switch/router, unless you are connected to your router wirelessly.
    A Cross-over cable simply swaps the orange and orange/white wires with the green and green/white wires.
    I'll provide a diagram of wiring below.
    ZT3000
    Straight RJ45 cable
    Cross-over cable (only ONE side is like this, the other side is like the straight cable)
  • Stevie Wonderboy Sep 02, 2007
    I've looked thru the manual but it did not mention a physical hardware button for reset purposes.
    Inspecting the item, is there any partially hidden or flush surface button that may reset the device. (it would probably be on the device's side that points down when properly setup)
    I'm really interested in seeing this device work!
I want change battery uniden cordless phone. I staying anand Gujarat India. Where is near service centre address and contect number. Hitesh shah
Sorry can't help with the service centre details but cordless phones mostly use standard type rechargeable batteries or battery packs that are easily replaceable and commercially available from various manufacturers and available from various outlets.
I suggest you extract the battery pack from your phone and browse ebay or Amazon until you find one that looks the same, using any type or part numbers to help.
If you really want to contact a service centre, these are often listed in the instruction manual or there is a variety of Uniden websites.
Jul 17, 2015 | Uniden Lands Phones
How do I use a new e mail address while keeping old address history for 30 days
Hi
I have always found the Gmail Help pages very useful, especially since you don't even have to be signed in to use them. If you go here:
3 ways to move email from other accounts to Gmail
there are various ways described to get your mail from other accounts, outside Gmail as well as within.
I would suggest that you browse through these and select the option you think most suits your requirement and then using two browser window, have the instructions open in one and follow them live in the other.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 16, 2014 | gmail.com
I THINK I've followed every instruction and tip regarding threading my machine and bobbin, but the needle won't pick up the bobbin thread. It just comes up as it went down, without the loop fr
Hi. Usually this is due to a wrong needle or your needle not being set correctly. Do you know if your patcher is a 29k? or?
http://www.parts.singerco.com/IPinstManuals/
There are various manuals at that link... hopefully your patcher is there. good luck
Jul 24, 2012 | Singer Sewing Machines
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Apr 26, 2012 | Office Equipment & Supplies
How do i clear my cache browers
This is from Chrome Help (there are more options, click the Spanner Icon, then Help) Clear your entire browsing history
  1. Click the spanner icon chrome_toolsmenu.gif on the browser toolbar.
  2. Select Tools.
  3. Select Clear browsing data.
  4. In the dialogue that appears, select the "Clear browsing history" checkbox.
  5. Use the menu at the top to select the amount of data that you want to delete. Select beginning of timeto clear your entire browsing history.
  6. Click Clear browsing data.
The following information is removed when you clear your browsing history:
  • Web addresses that you've visited, listed on the History page
  • Cached text of pages that you've visited
  • Snapshots of your most frequently visited pages on the New Tab page
  • Any IP addresses prefetched from pages that you've visited
Dec 10, 2011 | Google Chrome
Connection was refused when attempted to connect the proxy server
You can follow some tips when you make the changes in the proxy settings in Firefox. Obtaining your IP address is very important, and make sure that you are not giving the IP address to outsiders. Follow the instructions carefully; this will help you to make an easy change in the settings. And after the changes, you would be using the 'Manual Proxy Connection', so your details are not shared or traced by anyone on the net. To change the setting to direct connection, turn off the proxy and restart the settings. Now, you can make changes to the proxy setting. This feature in Firefox has enabled many Firefox users to have a safe and secure browsing.
Feb 11, 2011 | Mozilla Firefox
I have a Samsung GT S5233A handset with vodafone live enabled, I am able to browse internet in my handset, but I want to browse it through my pc windows xp, give me the settings for both my phone and pc
TRY ONE OF THE BELOW SETTING
1)To set up GPRS: a) Go to menu > Funbox > WAP Browser b) Select settings, and choose your profile Once you´ve selected the profile, complete the following fields: Profile name: Vodafone live! Homepage url:http://live.vodafone.in Security: Non-secure Bearer: GPRS IP address: 10.10.1.100 U sername: ______ Password: ______ APN: portalnmms Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WAP Browser > Home To set up MMS a) Go to menu > Messages b) Then go to Multimedia Messages > MMS Profile > choose your profile Profile name: Vodafone live! Homepage url:http://live.vodafone.in Security: Non-secure Bearer: GPRS IP address: 10.10.1.100 Username: ______ Password: ______ APN: portalnmms
2) a) Go to menu > Browser > Proxy settings b) Choose your profile Once you´ve selected the profile, complete the following fields: Profile name: Homepage URL: Bearer: GPRS Proxy use: Enabled GPRS setting: IP address: IP Port:9401 APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Browser b) Then go to current proxy, and select the desired proxy setting Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WWW services > Home
3) a) Go to menu > Settings b) Then go to Connection settings, and click on New Also, complete the following fields: Profile name: Homepage URL: Proxy: GPRS setting: IP address: Port:9401 Bearer: Advance setting: APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Browser b) Go to WAP profile, and select the desired proxy setting c) Then go to Options and click on Activate Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> > Browser > Home To set the proxy settings for MMS, go to: a) Menu > Messaging > Settings b) Go to Multimedia Messages, and select your profile c) Go to desired proxy settings, click on Options and select Activate Top X620, X650 To set up GPRS a) Go to menu > Funbox > WWW services b) Select Proxy Settings, and choose your profile Once you´ve selected the profile, complete the following fields Profile name: Homepage URL: Bearer: GPRS Proxy use: Enabled GPRS setting: IP address: IP Port:9401 Advance setting: APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Funbox > WWW services b) Then go to current proxy, and select the desired proxy setting Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WWW services > Home To set up MMS a) Go to menu > Messages b) The go to Multimedia Messages > MMS Profile > Profile settings > choose your profile
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
Incorrect email address The email address you entered does not belong to any account. You may try clearing your browser's cache and cookies by following these instructions.
Here are the steps on how to clear your browser's cache and cookies:
* For Internet Explorer:
1. Open your Internet Explorer and click on "Tools".
2. Go to Internet Options > click the "Delete" button under the browsing history.
3. Delete the cookies, internet files, and history > OK
* For Mozilla Firefox:
1. Open your Firefox > Tools > Clear Recent History
2. Time range to clear should be set to "Everything".
3. Expand the details and make sure that cookies, cache, browsing and download history are selected. > OK.
Thank you and good luck!
Nov 18, 2010 | Facebook Social Network
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I have trouble browsing the internet. I often get this message: Internet Explorer cannot display the webpage
You might be having a DNS problem. DNS (Domain name system) is responsible for changing the website name to the address (where the website is stored). You can try openDNS (www.opendns.com) The site can be confusing so here are the instructions. 1. Go to control panel > network connections 2. Choose the connection that gives you internet, right click on it and Click properties 3. Now select Internet Protocol (TCP/IP) and click properties 4. Check the box that says "Use the following DNS addresses" 5. Enter the following values (addresses) 208.67.222.222 208.67.220.220
Jun 03, 2009 | Dell Vostro 200 Desktop Computer
EnGenius EOC-3220 (EOC3220) Logo
1,694 people viewed this question
Top EnGenius Computers & Internet Experts
robert roberts
rdarell
Level 1 Expert
gggg
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
