Pyramid PB736GX Car Audio Amplifier Logo
Posted on Mar 22, 2009
Amp over heating and cutting off
Its a pyramid blue royal 1000 watt 2 channel high power mosfet amp.I think it's the fuse,it has a 20 watt on the side and a 25 on the battery. It's hooked up to 2 american legacy 10's but dosent blow fuses or speakers and it sounds fine when it does work.please help
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Mar 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
814
Points
6
Sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
1helpful
I've bought a pyramid crystal 1000 watt 2 channel amplifier used it states it runs at 4 ohms can I run it at 2 or 1 ohms and if so what will the wattage be?
Not to disappoint you too much, but the 1000 watts advertised is just marketing hype. If your amp is the PB781X, it should have only a single 15A fuse on it. Your battery provides 12.5 volts when the engine is off, so at most, your amp draws 187.5 watts of power. Draws, not outputs. No amp is 100% efficient due to heat. When your engine is running, assuming your alternator outputs 14.4 volts, your amp's maximum power draw is about 216 watts. Again, this is what your amp draws, not what it puts out. What you should focus on is the RMS (continuous) output, not Max or PMPO. Those numbers are useless, unfortunately.
Your amp is rated to output 50 watts per channel at 4 Ohms, and 75 watts per channel at 2 ohms. This is when wiring your channels separately, not bridged. I did not see true power specs for your amp while bridged, but it's possible you'll just get the full 150 watts to the single bridged output. Do not attempt to apply a 1 ohm load to your amplifier, as you will run the risk of damaging it. It's not designed to handle a 1 ohm load. If you're lucky, you'll blow a fuse before the amp is damaged, but either way, there is nothing to be gained by attempting it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
1helpful
I have a pyramid amp and i don't know what watt it is and it doesn't say. the model no. is PB-700A. it's an older amp thank you
  • 4-Channel
  • 350W X 2 Max @ 4ohm
  • 700W X 1 Bridged @ 4ohm
  • Dim: 2.4"H X 10.7"W X 6.9"L
  • Mosfet Pwm Power Supply
What does it mean when the red IND PROTECT light is on? my subs cut in and out, mostly out with the occasional hard hit popping up in the middle of a song. Whats wrong?
You've got the gain to high and the amplifier is clipping the sound frequency causing it to distort. Possible problems are you have a bad speaker(s) and the reading is below 4 ohms. Each of the 4 channels can only take 4ohms. If your bridging 2 speakers to this amp you have to also make sure you are only bridging 4ohms anything lower will cause the amp to overheat. Dont put 2 speakers in parallel on one channel or you will definitely have more problems.
The protect led has turned on and will not allow the amp to work. I've tried re-wiring the whole unit, changed the fuse to a high wattage, I've given it time to cool off in case it was over heating. Ive...
mosfet have a built in shut off incase of a blown resistor, if the resistor blows,it will shut down the amp, the resistors job is to inhibit power to prevent overheating, you will have to check the OHMS of each resistor to find out which one has gone......hope this was helpfull
1helpful
1600 watt pyramid royal blue 2 channel amp need diagram of amp itself
if i keeps blowing fuses then it means the amp is bad
1helpful
Pb1281x pyramid crystal 2ch mosfet amplifier 1600w what size fuze i got a 20amp in it it blows when i got it terned up
Hello sunshanel,
You did not say what you have the amp connected to and what the impedance load is. It is only stable at 4 ohms and if a lower impedance is connected, say 2 subs in parallel, it would try to produce more power when you turn it up and would most likely blow the fuse. 20 amp sounds right for the amp. The power rating of 800 watts per channel is peak power, not RMS, and many low-end manufacturers tend to state bigger numbers in the ratings.
Hope this helps.
I need to know what kind of fuse my amp takes...
IT MAY MEAN THAT IT TAKES (2) 25 AMP FUSES
IF YOU HAVE THEM OUT SEE IF IT SAYS WHAT THEY ARE OR OPEN IT UP IT MAY SAY IT ON THE BOARD OR THE FUSE HOLDER OR LOOK @ THE SPECS ON THE AMP SEE WHAT THE TOTAL CURRENT IS YOU CAN ALWAYS START WITH A SMALLER AMPAGE LIKE 10 -20 AMP FUSE ALWAYS GO SMALLER
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
