Question about Maytag MMV5165 Microwave Oven
Maytag MMV5165BA - E-63 on display
After popping Popcorn using the Popcorn button, the display reads E-63. What does this mean?
  • 2 more comments
  • dcljb Dec 06, 2007
    Same issue - happened twice about 10 minutes apart on microwave I've had less than a month. Didn't pop as many kernels. Able to clear each time and use again. Third time it worked fine.
    dcljbenge
  • booglu Dec 29, 2007
    Tried 3 times to pop popcorn with really bad results (very few kernels popped, and what was, was burned). Tried with a new bag and got the "E-63" message, and now the fan won't turn off either!
  • jgaron603 May 24, 2008
    same problem - brand new microwave. Did you find a fix?
  • Anonymous Mar 01, 2009
    Is there a solution?
  • Maytag Master
  • 9,098 Answers
Sounds like a problem with a temperature sensor or humidity sensor.
Posted on Oct 12, 2007
Microwave doesn't popcorn all the way on popcorn seeting
Most M/W use an estimated setting based on ounces of corn. I've found that many do not tell you how much is in each bag. The bags usually have no size markings. Check the face of the box for something like "2 each 3 oz bags".
* Try to use a normal re-heat setting (at full power) and cook a bag using the a minute longer than the recommended setting. Listen to the popping sounds and stop the M/W when the pops slow to 3-4 seconds. (2-3 seconds with 'Kettle' corn) Note the time lapsed and this is your correct setting. You may try the popcorn menu to find a similar setting but really your best bet is to use the method above as it's the most accurate.
* Note; Old or stale corn will not all pop (it dries out as it gets older and there is not enough moisture in the kernnal to steam pop.)
* M/W varies from model to model and brand to brand. Only way to check is to try several settings to get the best results.
* Pop corn brands vary in quality. You will find the better name brands pop more.
* Once you find a good popping brand then stick to that size and brand. (unless they change it on you.)
* If your really stuck on getting every corn kern popped then go with an air popper. It won't come out of cooker till it pops.
Good movie, don't forget the goobers, milk duds, frosty...
Aloha, ukeboy57
May 28, 2018 | Microwave Ovens
Maytag microwave overheated and shut off - Model #MMV5165BA
That is not good, the magnetron has gone, or the thermal fuse has failed, "protects the magnetron from overheating" There is a possibility the keypad control board was a affected.
Apr 07, 2012 | Maytag MMV5100A Microwave Oven
I recently bought a Whirlpool microwave. I would like to know if there is a manual telling how to use the buttons on the keypad? When the button says "popcorn" I have no idea if I just push...
Here is a link to a the product page for one standard Whirlpool microwave model currently available:
http://www.whirlpool.com/-[MT4155SPQ]-1001410/MT4155SPQ/
And here is a direct link to the User's Manual for that microwave oven (model # MT4155):
http://www.whirlpool.com/digitalassets/MT4155SPS/Use%20and%20Care_EN.pdf
To view the Product Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions on how to use the POPCORN feature in that microwave. Here is an excerp from that section of the manual:
To Use POPCORN:
1. Place popcorn bag on the turntable and close the door.
2. Touch POPCORN once for Regular, or twice for Snack.
Touch START, or wait for the microwave oven to start the
popping cycle automatically.
When the cycle ends, "END" will appear in the display, and
the end-of-cycle tones will sound, followed by reminder
tones.
3. Touch OFF or open the door to clear the display and/or stop
reminder tones.
I hope that was helpful to you, good luck and take care.
Joe.
Oct 03, 2011 | Microwave Ovens
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
Dec 29, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
Dec 23, 2009 | GE XL1800 1100 Watts Microwave Oven
We have a brand new Maytag mmv5165BAS over range microwave oven. When we tried to make microwave popcorn using the 'Popcorn' control, the microwave stopped early and the display read E-63. What does...
E63 is a "T1 Max Time" error. It indicates a problem on the control board.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Keep a close eye on it, and if it fails again, you want to contact Maytag for free warranty repair.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 24, 2008 | Maytag Microwave Ovens
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
Jan 06, 2008 | Magic Chef CMV1000B Microwave Oven
Maytag MMV5165 Microwave Oven Logo
536 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
