Question about Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio MP C1500SP - functional error SC202
Printer stop to print in black color.After replacing black cartridge I have got message error : ERROR SC202 ...FUNCTIONAL ERROR Is there any Ricoh manual with service codes explained? Thanks
  • 3 more comments
  • Anonymous Dec 09, 2008
    I have the same problem, but this is sadly enough not the first time, nor the last, I suppose... I think it's been a year since I got it, and it has shown an error at least 5 times! It takes a week every time I call for service... Why can't they make an online help-site??
  • Anonymous Mar 13, 2014
    Need to print only with authorized code on printer MP3351
    ricoh mp 2030 error code 400
  • Anonymous Mar 17, 2014
    How do you override the "Replace Print Cartridge" message on a Ricoh Aficio C320DN color laser printer? The printer has stopped printing but there is clearly still toner left if the cartridges.
  • Anonymous Mar 24, 2014
    Trying to use scanner feature
Call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
SOURCE:
I have a Ricoh MP C2500 and it shows SC202 error How do I fix this
Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
May 24, 2016 | Ricoh Aficio Mp C2500 Color Laser -...
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
Error code sc202 on infotec isc615g
SC202 is a problem with what is called the polygon motor, It is the motor in the laser unit and has most likely failed.
Jul 14, 2010 | Ricoh Aficio MP 161SPF Color Copier
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio 1515 All-In-One Laser Printer Logo
7,264 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
