Question about Yamaha RX-V2400 Receiver
Receiver goes standby everytime I change settings
The receiver works fine as long as no setting such as Speaker level,stereo to 7 channel/dolby (or vice versa) is not changed. It has happened after a recent lightning strike on satellite tv receiver antenna entered the satellite receiver via the coaxial cable,passed through the RXV2400's body cover and then through the subwoofer output cable in to the subwoofer electronics and thereon to the earthing of the AC supply.At the time of strike,all units were switched off ( Not Standby) still the damage occurred because of lack of earthing,learnt after incurring a great cost! Please suggest remedies.
  • Tinkal Aug 27, 2007
    I have further noticed that during the few seconds between power on and speakers relays being on all settings can be changed without affecting the unit,but any change after that will make it go in to "off mode" with the displays off, speakers off with a thump etc. Again,the unit goes off mode when the Audio CD player (Connected thru coax)is switched off while it was playing,which was not the case before the lightning strike.When the unit is up and running for say 10-15 minutes, it accepts change of soundstages say from stereo to Church/Rock etc with a largish thump of speakers without going in to off mode.It does not accept changes in soundstages from Dolby/DTS to 2 Channel Stereo nor speaker level setting etc and goes off in any case.
    Thanks for going thru this longish description of symptoms.Looking forward to your suggestions.
  • Tinkal Aug 28, 2007
    The remote/buttons on the unit both yield the same result.I have tried it without the sub woofer connected, as the subwoofer electronics was badly damaged.As I have explained earlier, the lightning surge came in via the satellite coax to the satellite unit, which incidentally touched the casing of the Yamaha unit.From the casing of the yamaha unit it found an outlet in the output cable going to subwoofer(SWF)through the RCA plug .While at subwoofer it finally found the AC earth as the AC supply cable to SWF was 3 pin and in all else (Satellite indoor unit and Yamaha unit) only 2 pin(Phase and neutral).As you might imagine,the subwoofer outlet (RCA plug)at the yamaha unit and nearby earthing(DC) area of the PCB on which it was mounted was completely fried.I also suspect it is probably a case of some earth wire that has burnt,but unable to locate where.I have repaired the burnt PCB with copper wire soldered wherever required.I will upload the photo next time.Meanwhile, let me look at the main PS board and the control unit DC earths and report back to you.
    Thanks & regards..
    tinkal
  • 944 Answers
What if anything have you had replaced/fixed so far? a fairly likely problem is going to be IC (chip) damage in the control electronics, also quite a number of soldered joints could need attention, all components could potentially have been damaged in some way. I mostly suspect it would be a problem in the power supply/conditioning part of the unit, in particular the ground/earth connection from the main control circuit board to the power supply. Also make sure the main power cable of the unit has a good earth still. If you want a bit of help checking this yourself, you will need a multimeter, possibly an ESR meter, a soldering iron and a digital camera. post us a shot or two of the inside and we can hopefully talk you through what to check. An independent ground for this sort of unit is useful and cheap and easy enough to do - please ask again if you want help with this. Hope this helps :)
Posted on Aug 28, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Aug 28, 2007
    ps - have you tried it without the subwoofer connected yet?
    pps - the main control board ground probably goes directly to the case, as does the external ground connection.
    ppps - are you using the remote or buttons on the receiver? there could be a problem with the remote recieving part.
SOURCE:
When I turn the receiver on the the TV automatically plays in stereo mode. If I channel up it will switch to Dolby surround. How do I get it to start up in Dolby surround?
Not all channels broadcast in Dolby. The receiver will automatically switch to Dolby if it detects a Dolby signal. I can't be specific about the receiver as you have not stated a model. A lot of the switching depends on what sound setting the TV is set to broadcast. What settings you have set the receiver to. Plus the connections between the two. For best sound quality connect them by optical cable if both support it.
Jan 31, 2016 | Audio Players & Recorders
How do I get my sound back on my receiver. a red light is on it
HI David, please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "CBL/SAT" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings. If the reset does not correct the problem please give our Product Support Team a call at 800-229-1687 as they are available 24/7 ready to assist, Thanks, JT
Nov 15, 2015 | Onkyo TX-NR626 7.2 Channel Network A/V...
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at [email protected], Thanks,JT
May 04, 2015 | Onkyo Audio Players & Recorders
TX-SR333 Bluetooth worked the 1st time now won't pair up.
Hi, Please try the following reset and then try to pair again.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "CBL/SAT" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Feb 27, 2015 | Onkyo TX-SR333 5.1-Channel Home Theater...
No sound from back channels of my dtr-7 stereo receiver
Do a Factory reset. it's most likely a speaker setting issue. press VCR and wille holding it press the Standby button. once you see clear on the screen it is done. try it now!
Nov 09, 2011 | Onkyo DTR7 Receiver
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
Volume trouble with 37LG30
well if you want to get rid of he tv i offer to buy it from you
[email protected]
Feb 03, 2009 | LG 37LG30 37 in. LCD HDTV
Center channel
Back to basic to advance:
Be sure you have all speakers connected correctly behind the receiver.If you center channel don't have any sound,it could be 7 different issues,but you could try to just hook up your center channel to either the right or the left speaker output to be sure the center channel speaker does work.
Check your the speaker wiring tip(if there is any),i will use just the speaker wire go straight to the center speaker output,go to the receiver to change it to pro-logic or dolby digital and of course you should put in a dvd in the dvd player to have a good quality movie to play the dialogue through the center channel for you test.
If you have tried the above step and still have no sound,you might consider hiring a troubleshooting master to take care of your issue.
Let me know what you need!
solutiondoct
Nov 05, 2008 | Pioneer VSX-455 Receiver
Yamaha RX-V663 wont play rear surround
The best way to get Dolby sound working is to connect the components using the optical links.
As long as you are using PCM the Dolby sounds will never get to your system. It's switching the Dolby sound off as soon as it detects PCM. I think the only way you will get Dolby on is via a optical cable which should let you have bitstream.
Mar 12, 2017 | Audio Players & Recorders
Yamaha RX-V2400 Receiver Logo
125 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
