Question about Samsung HCL4715W 47" Rear Projection Television
Blue is mis-aligned.
I hope I cab get some help here. My Samsung just started going blurry off and on.. then finally blurry all the time now. When I try to use perfect focus, the blue color is to the far right and does not come back to the middle. Does anyone have a clue to what this might be or is it trashed? I'm a computer tech, so I have no problems replacing parts.. I just wouldn't know what part to replace. Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
You need to replace the two convergence IC's - part# STK392-040. Also look for burnt/discolored resistors near the IC's
Posted on Aug 22, 2007
SOURCE:
I have a Samsung HL-N4647W 42 inch HDTV DLP TV and the screen is blurry and out of focus with a black curved block across the bottom. what can I do to fix it?
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Samsung HL-R4264W 42" DLP HDTV
Magic focus blue is fine, green and red are really blurry, tv picture is almost black and white. all bulbs are on.
Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the convergence board,to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 13, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My Hitachi 43fdx01B went from a perfectly clear picture to one with red "ghosts" and very blurry. I my TV toast?
No,ur tv have a problems,known as a convergence problems,it dead.Very common problems on the DLP tvs design flaw.Most commom problems are R,G,B mis alignment,will not align,Colors shadows pictures,3D pictured and blurry?The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors are dead,must changes to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 26, 2010 | Hitachi 43FDX01B TV
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
BLURRY PRINT OUTPUT
The head probably needs aligning.
An interum fix is to turn off bi directional printing in the preferences.
This could possibly solve the problem.
Jun 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Convergence problems
I would suggest the convergence ICs as well as a couple resistors right near the Convergence ICs mst likely. 90 % of the time thats the problem. They are not expensive, if you can solder you can handle it if your careful with your solder and use heat sink compound. The ICs will have a number stamped on them usually STK XXX-XXX on a huge heat sink. The following link will have replacement parts http://electronix.com/ Hope this helps you out
Jan 11, 2008 | Panasonic PT-47X54 47" Rear Projection...
Samsung BP95-00142E Convergence Board changed still having a problem with the blue color
Actually the TOP Left blue corner cannot be allinged properly thru manual blue convertion.  Red is aligned correctly.
Oct 30, 2007 | Samsung PCN5425R 54" Rear Projection...
Toshiba 57h81
Go to the convergence and align the red and blue + - Under Menu then Picture then convergence to get to this screen- Hope it helps
Mar 24, 2007 | Toshiba 57H81 57" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
