Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Needle Borke and cannot take out!
I was sewing and did not take a pin out and it broke the needle on the right. We can not remove the needle. We have lost the manual. Please help, We are trying to finish a project before my bother gets back from Afghanistan.
There are small holes on the metal block where the needles insert.  These holes fit hex/allen wrenches (I'm not sure the size).  Turn the wrench to the left to loosen, and the broken needle should either fall out or be loose enough to pull out.
Posted on Oct 23, 2007
Singer 7430, Needle hits the bottom of the bobbin case.
when the needle breaks on a pin that can cause a
problem with the timing, the machine needs to be serviced
Dec 11, 2012 | Singer 7430 Sewing Machine
When I'm sewing a seam the needle always hits the straight pins. I've checked the needle, removed it and put it back in. When it hits the pins it almost always breaks the needle.
When you are sewing you are supposed to take out the pins as you go to avoid the needle hitting the pins.Sew a little and remove a pin,sew a little more and remove another pin.That's how you do it.If you hit a pin change the needle it will most likly be bent or blount after hitting a pin. www.sewvac.com
Feb 03, 2011 | Singer Sewing Machines
I am sewing a quilt and my needle is in the right place but it keeps breaking. Please help. Also, the thread break often.
here are something you might check
upper thread breaks
1.top tension to tight
2.thread to thick or to fine for needle
3.needle not inserted correctly
4.thread caught on something-spool pin, tension area
5.needle damaged
6.needle thread is not threaded properly
Needle breaks
wrong size needle for fabric
wrong foot is attached
needle clamp screw is loose
also check for lint & pieces of broke needle under the needle plate
also the bobbin case area -take the bobbin & case out & check for pieces of broke needle
here is a tip about needle & thread
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 21, 2010 | Husqvarna Designer I
Designer SE hit pin head while sewing.
did you take out the whole bobin case and see if it has a piece of the broke needle in there?
Jul 22, 2010 | Husqvarna Viking 1
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Keep breaking needles
Here are some solutions to try.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
Self threader won't work
the needle should be in the up position or the threader won't come down, still when it does, you have to get the thread right across the hole in the needle for it to catch,
another problem is that you bent or broke the center pin that pulls the thread through the needle,
the tip that comes to the needle has three parts, the two outer ones that wrap around the needle and the center pin that goes through the hole in the needle,
If this is bent you may be able to bend it back if broke you need to get it replaced
take a good magnifier and take a look at the center pin!
Hope this helps
moni
Sep 06, 2009 | Singer 3116 Simple
My Janome needle thread will not pick up the bobbin thread! I have checked threading and needle and bobbin case...nothing works!
Your Machine is out of time, you probably broke a needle or sewed over a pin. take the machine to your locsl deler to be re timed. about 90.00
Jun 13, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing machine, strange noise
Is the needle in right? There is a front and back to a needle. Also is it the right needle for the machine?
Dec 07, 2008 | Singer 7462 Mechanical Sewing Machine
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
64 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
