Question about RCA F27664 27" TV
Parental locks ok ive tryed the solution for unlocking blocked channels was wondering if it made a diffrence that i was useing a unversial remote but still cant get locks off
    Novelist:
    Champion:
  • 236 Answers
If the universal remote you're using is an RCA it should work for you. Other brands probably won't. Stargazer
Posted on Aug 29, 2007
SOURCE:
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
Jul 21, 2015 | Philips Televison & Video
RCA 2004 24V511T no remote CPA is locked!!! What can I do to unlock??
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
google.com/+GopakumarGopalan
Dec 20, 2013 | Televison & Video
How do i unlock lost or forgen password.?v hold
May 24, 2013 | RCA E13320 13" TV
Apex model #AT2704S front panel buttons stop working? Menu, channels, volume, and power? Also has a red key in lower left corner and the screen is blue. I have tried mute and function buttons on univ
Your Apex TV has been locked by anyway. Just try this method to unlock it.
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Feb 07, 2013 | Apex Digital Televison & Video
No chanels
The TV is locked electronically. To unlock it, you must have its remote control. If you have its remote control,
Lock the controls to activate the changes using item six on the "Parental Controls" menu. If you wish more details abut RCA TV unlock proceedings, check this site.
Jan 23, 2013 | RCA F27665 27" TV
Unlock pin on hannspree 22
Sep 17, 2012 | RCA 24V511T 24" TV
How to unlock childs security?
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
How do i unlock it
Mar 10, 2012 | RCA 24V511T 24" TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Locked tv
The Digital Channels are Blocked and Some of the Annalog Channels are Blocked that you can't access some channels and how do you unblock the channels by getting rid of the Code for Parental control?How Do you get rid of the Parental Code to acess all Channels .
May 27, 2008 | Apex Digital GT2011S 20" TV
RCA F27664 27" TV Logo
64 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
