Does your PlayStation manual has any info on how to synchronize with your PC? If not open your network places, add the PlayStation details, which should be given in the manual, thentry synchronisation on auto mode. Most probably you will have to enable IEEEE802.PSupport in the network adapter properties window....sodeep
While setting up anew connection use auto detect settings or whatever settings you have been instructed to enter in the field:IP Address, which if it is a dynamic IP then set your PC to ***.***.***.2 an the default subnet mask and then the Gateway which has to be same for both. If you have been given DNS settings enter the same value in both but give your playstation IP as ***.***.***.3. Now restart your PC. Open network neighbourhood and check if your playstation appears if not add it, while connected to the internet. Also look up the user manual of the playstation too. Visit the playstation manufacturers website to check, it should be able to detect your playstation. Then share both and synchronize and enjoy......sodeep
Yes, you should just select DHCP from the network section. You might have selected STATIC by mistake. If you select DNS, then this should automatically add or your network information, including the DNS address. If not, try adding the IP address of your router, which is usually 192.168.1.1. or 192.168.0.1. Hope this helps . .
The WEP key is your SSID key. Basically, your wireless network has a security password to let you get on your network. If you don't know it or forgot it, then you need to go into your router setup by typing in the routers IP address (usually 192.168.1.1 or 192.168.0.1) in a web browser such as Internet Explorer. Look for wireless settings tab and enter a WEP key and enter any WEB key you would like to use.
Yes, you need the code or you need to log into the D-Link router and re-configure it from a desktop/laptop computer. You also might need the password to get into the router. If you dont have that password, then you need to set the router to factory default by holding the little button on the back of it for 30 seconds. After that, the SSID might be D-Link and you should be able to connect to that with no WEP Key.
good stuff,but not quite there,do you what wep key is
never tried that yet thanks for the help
do you know what the aoss button is
?If my wife mother buys the first computer in the house hooks everything up in her room upstairs and then I guess bought this d-link to hook up my wifes computer down stairs ok, and then Hooked my I pod touch to the same connection,and she forgot the security code so now I can't hook up my playstation without her code?
any body aoss button what and were is it
bout to kill my playstation 3 and t.v. please help S.O.S
DIE DIE DIE
DIE DIE DIE
Thanks bro thats so deep!
if you hook up the usb from a digital camera or I pod can you put pics on the ps3 using camera's usband music from the ipod usb?
anybody there
