Question about Maytag Neptune MAH9700 Front Load Washer
Maytag front load 9700
Control lock light is on. Cannot use the control knob. Have unplugged machine, but "control lock" light stays on
    President:
  • 331 Answers
First things first... please follow this link to see if your machine is part of Maytag's recall... http://www.washerrecall.com/ or this site for details on the recall... http://www.cpsc.gov/cpscpub/prerel/prhtml07/07135.html
Posted on Aug 19, 2007
How to correct control locked will not go off on whirlpool ghw9150 washer
While the machine is 'on' press & hold the "end of cycle" button for 3 seconds, or till the lock light goes off. This is on the far left or right of the machine's panel. Good luck! Pl rate me.
Sep 01, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Control lock stays on
Try holding for 3-5 seconds should unlock controls.
Jan 20, 2014 | Maytag EPIC MFW9600S
My washing machine has a light on on the front with the label control lock. How do I get that off so I can continue to use it. I tried to unplug it and it came right back in when it was plugged in.
Press and hold the botton that says control lock on or off////be about 3 seconds might be two buttons at one time//that will unlock the control....good luck please vote...............thank you
Feb 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
CONTROL PANEL LOCKED LIGHT ON, WASHER WONT WORK.TRIED UNPLUGGING TO RESET.
Press END OF CYCLE button and hold it for 10 seconds.. It will turn of the control lock feature..
Oct 06, 2010 | Maytag EPIC MFW9700S Front Load Washer
Control locked
If you have a front loader then Press and hold the "end of cycle" button for 5-10 seconds and it will reset the child safety lock.
If the control locked light will not turn off, I recommend unplugging the washer for 5 minutes. Plug the unit back in and see if the controls will respond. If not, You could have a failed control console or a bad electronic control board in the washer.
Jun 19, 2010 | Maytag EPIC MFW9700S Front Load Washer
Unlock the control lock
Jun 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
May 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Maytag Neptune front load washer with FL code
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
faulty door lock solenoid
loose wire connection
faulty door lock switch
faulty door lock sense switch
bad control board
I recommend calling a service technician to diagnose and repair your washer.
but try this first just in case....unplug it for 1 minute plug back in and see if the fault code clears.
good luck.
Jan 03, 2018 | Maytag Neptune MAH5500B Front Load Washer
Main Control Knob Removal
Pull the knob off, some units have a set screw that holds it inplace but most are just tight fit. May need to pry it off. The screw that holds the control in the front plate is under the knob. Take the back plate off which is just behind the control. label the wires as you remove them or unplug one wire and put it on the same plug on the new control.
Feb 03, 2008 | Maytag PAV2300 Top Load Washer
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
197 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
