Question about Samsung HP-R4252 42 in. Plasma HDTV
Purple and white distorted fuzzy lines running up and down and side to side on tv
I have a Samsung HP-R4252 plasma 42in. It worked great for 6 months, with an occasional wierd "Glitch" as I like to call it here and there. The top half of the TV would blink, then turn into a sorta blurry/fuzzy rainbow colored assortment of lines that went side to side, with no visible picture behind them. A solid mass of colors and fuzz. This happened on and off for the next 6 months, and like a dummy I didn't have it serviced. Now that the warranty has expired, it finally blew up. The lines have moved from the top half of the tv, to the lower left corner, and it is constant. The lines run up and down, and side to side, moving with the picture displayed in the section of the screen. Multi-colored and mostly purple, fuzzy and VERY annoying. They are not solid anymore, but almost like a plad pattern you would find on fabric. I have tried everything Samsung told me, besides getting it serviced. I am not affraid to take it apart, as I am a certified computer repair technician and certified Automotive mechanic. By this I mean I know what not to touch. (Capacitors, Transformers, blah blah) If anyone has any suggestions, please let me know. Thanks!
  • 1 more comment
  • Grantw73 Aug 27, 2007
    I purchased a service manual for the tv, and took it apart. From the diagnostics diagram I followed, it suggested buffers. Sure enough, both the upper and lower y buffer boards have gone bad. Estimated $600 to replace. Time for a new tv! Thanks for your help.
  • spiky_tp Mar 04, 2009
    I bought my Samsung HP-R4272 about 3.5 years ago. A couple months ago, the bottom half of my screen would randomly go completely black for a few seconds. Then the top half would occassionally blank out as well. Now, the bottom half and about 2/3 of the upper half show that purple haze (with horizontal and vertical plaid-like lines). I do have about 3 inches horizontally that work...
    I've read up on some other sites on potential fixes and here's the parts they replaced:
    BN96-02216A (p-y buffer lower board)
    BN96-02033A (p-y main board)
    BN96-02034A (p-y buffer board)
    I'm not sure if replacing these 3 parts will solve the problem?
  • Anonymous Mar 14, 2014
    Blue line running down left side of screen, sometimes a multi colored line flickering on and off right next to it.
Hi i myself have a problem with my samsaung where the picture is there and sound ect, but the picture is speckerly with colour just like a mesh efect . after sometime the picture will come perfect and stay like that until i switch the tv of . then when switched back on the fault returns any ideas
Posted on Nov 06, 2007
I just had my lower Y-buffer board swapped out to fix a problem similar to yours. After an hour and a half of on-time, the lower half of the screen would flicker on and off with the same appearance you mentioned. Changing out this particular board fixed it for me. However, since it has gone from top to bottom on your set, it may be more of a main board problem for you (that controls both upper and lower halves). Beyond this, I don't know any more. I am considering getting a service manual to gain more knowledge about the various PCBs in the unit so I can fix any future problems myself.
Posted on Aug 27, 2007
Samsung hp-R4252 can you remove the soundbar, for appearance reasons? Just hook up sound through stereo?
no the sound bar is not removable unless you cut it off i would suggest steping up to a new led tv great for picture and mounting on the wall ultra thin this tv got really poor reviews
Jan 06, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
Red lines on top of the Samsung HP R4252
This is a very common problem. Most likely it is the y upper and lower buffer, and I would change the y main board as well. Here are the part numbers:
BN96-02033A, BN96-02034A and BN96-02216A about 360$ total in parts.
Thank you,
lee
Aug 25, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Top half of screen goes blank.
Replace Y drive and Y sustain boards or check for loose cable connections on the LEFT side of the panel when viewed from the back - delicate job.
May 27, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung Plasma HP-R4252
One fix will not repair all sets, It could be the logic board or just as easy The Y or X boards, or mabe a simple LVDS cable. But to just buy board till the set runs could get real spendy, so best advice is to take it to the shop
Jan 30, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Plazma TV
There are several shutdown circuits on this unit. The X main or Y main are the usual suspects. Call 1-800-Samsung for a qualified servicer in your area.
Jun 07, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
980 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
