Question about Nikon Coolscan III Film Scanner
Problems with coolscan3 and AMD64 machine
I am having trouble getting my pc to run mycoolscan3 (SCSI. I have installed nikon scan 3.1, the correct apsi software and the device manager says the scanner is working properly but no joy either standalone or through photoshop etc. My pc is using an AMD64 x3 dual core processer. Everything is properly connected and I have run through trouble shooter unistalled/reinstalled everything several times. It all worked perfectly on my p4 machine. Any suggestions _
  • rockhound Aug 19, 2007
    My old P4 machine was using XP pro with sp2 and the scanner worked??
    Scholar:
  • 85 Answers
Hi, please find enclosed a link showing nikon scan compatibility with different operating systems if you are using xp 64 bit or 32bit the table is showing that your version of nikon scan is not compatible http://nikoneurope-en.custhelp.com/cgi-bin/nikoneurope_en.cfg/php/enduser/std_adp.php?p_faqid=7894&p_created=1068557916&p_sid=LeP*VyJi&p_accessibility=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAmcF9wcm9kcz0yNSwzMSZwX2NhdHM9MjQxLDE3OSZwX3B2PTIuMzEmcF9jdj0yLjE3OSZwX3BhZ2U9MQ**&p_li=&p_topview=1 hope this helps
Posted on Aug 19, 2007
  • atlas  repair
    atlas repair Aug 19, 2007
    hi
    the link i gave you says that you need to update your scanner's firmware here's the link you need for this http://nikoneurope-en.custhelp.com/cgi-b...
    try that and your scanner should work fine
    make sure you use the most up to date driver too
    let me know how you get on
    atlas
Konica Minolta Dimage scan dual film scanner will not connect to windows 7
It's possible there are no drivers running under W 7 for this remarkable unit and it's a shame .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD .
You could also partition your HDD and install W XP on the new one .
Otherwise ... trashbin . Yes , life is hard .
Regards .
Dec 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
I would like to connect my old SCSI coolscan iii
If your macbook doesn't have the correct SCSI card (SCSI II - d-sub mini 50 pin x2 connector) installed, you aren't going to be able to do this. You will need to find this SCSI card and install it in a computer that will accept it.
Rich
Dec 16, 2009 | Nikon Coolscan III Film Scanner
Coolscan 3 and Windows XP
Try a good scanner program called vuescan. Much better than Nikon software. I have been using on XP for a long time and no problems
Mar 25, 2009 | Nikon Coolscan III Film Scanner
Nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on adaptec.com site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Mar 22, 2009 | Nikon LS 2000 Film Scanner
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
PC (Dell) won'r recognize scanner (nikon ls 2000)
This is a problem with SCSI bus speed too fast for the legacy device. The recommended SCSI controller is the Adaptec 2906, which will recognize legacy devices and slow the bus speed for them.
You also need an older ASPI driver set, version 4.70 available from Adaptec at http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi_v470_exe.htm
Before you install the 4.70 version you need to be sure to remove any newer versions of these files: Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}ASPI32.SYS Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WOWPOST.EXE Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WINASPI.DLL Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WNASPI32.DLL
These files may be found in WindowsSystem or WindowsSystem32. In order to delete them, you will need to restart your PC in Safe Mode. Once they are gone, restart your computer normally and run the ASPIINST.EXE program which was extracted by running the file downloaded from Adaptec.
Finally, you need Nikon Scan 3.1.2 for the LS-2000, available at http://support.nikontech.com/app/answers/detail/a_id/81
Nov 18, 2008 | Nikon CoolScan V ED Film Scanner
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Drivers for Nikon LS 1000
I believe that's a SCSI-interface scanner, making its setup more complicated than there's room for here. Here's what Nikon says about SCSI setups: <http://tinyurl.com/2wxp7p> and the Nikon software for the LS2000 and LS3000 (but maybe it'll work for the LS1000 too) is at <http://tinyurl.com/2qko5e>. There's a good set of detailed installation instructions under cineman's entry at <http://hardware.mcse.ms/archive47-2005-6-203500.html>. Good luck!
Lenny
Feb 11, 2008 | Photography
NIKON LS2000 SCANNER
this scan works with SCSI interface not provided by default in PC. So scan uses to come with SCSI board .. you need to install it into your PC .. yes
Nov 19, 2007 | Nikon LS 2000 Film Scanner
Coolscan 3 will work on my new pc with amd64 x2 processor
I know some devices may not work properly or will not work period if your running a 64 Bit processor. I would recommend to contact the manufacture of your scanner & verify this. Possibly they may have 64bit drivers. Hope this was any help to you.
Aug 19, 2007 | Nikon Coolscan III Film Scanner
Open Questions:
Nikon Coolscan III Film Scanner Logo
279 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
