Question about Frigidaire FSC23F7D Side by Side Refrigerator
Ice does not dispense
When I press the dispense lever no ice comes out. However the water gets activated
  • 183 Answers
It may be auger motor is frozen up, try to defrost. Regards Advisor
Posted on Aug 21, 2007
SOURCE:
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
The water dispenser on my GE fridge, model bss25jsrss, doesn't work. There is water in the lines, and the lights in the front work, but when I try to get water or ice nothing comes out.
There is a simple switch behind the push lever which activates the water/ice dispenser circuit. Sometimes these switches are poorly engineered to the lever with an adhesive or plastic rod which will break away. This is the first place I would look for a culprit.
Sep 25, 2011 | GE Refrigerators
When pressing water lever the ice comes on and when pressing the ice lever the water comes on.
The switch is defective or the switching mechanism isn't working. Gently pry the dispenser cover off to access the screws to get to it.
Jan 16, 2011 | Frigidaire FRS3R5EMB Side by Side...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
The ice maker stopped working, still get water to dispenser. fan works, don't know whatelse to check?
If your freezer is working, and water is reaching the ice fins/tray; check that the metal wire lever is in the down position for dispensing water and/or up for when ice is ready. The lever activates a small valve that allows water to drip onto the ice fins/tray...
Jan 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Mar 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile Refrigerator will not dispense ice.
see http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
Feb 21, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
66 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
