Question about Pioneer KEH-1500 CD Changer
Jvc sx-dw303 no output from amp power light low could you allso tell me transister equiverlent to d2395 there is no aviuse clues to this problem had visuel look at all joints,coulple of areas have got hot checked seem ok
I have exactly the same problem with the JVC SX-DV303. It's like no power can get through. This is posted in the wrong section, i will post in the correct section, see if anyone knows of a solution there! :)
Posted on Sep 27, 2007
Brand new pioneer 820 watt amp worked for about ten minutes, now the speaker output light flashes on and off
You didn,t have the sub wire up properly, End fried the output transisters in the amp. Or it was not set (Properly)
Nov 05, 2012 | Pioneer Car Audio & Video
Horizontal transister heat up and shortens
Try to replace new harizontal output transistor.Before replacing the transistor,check the regulator and the flyback if shorted or not.If the flyback is shorted the harizontal output transistor will be damage again if you trying to turn on again.Thanks..
Aug 26, 2011 | JVC TM-2703SU 27" TV
I purchased an old Realistic TRC-431 CB. When I turned it on it worked fine, the mic was keyed then the lights went dim and stayed dim. Now the lights remain dim. I checked the two output transistors...
The problem is with your power supply. There should be a big round transister on the power supply this is the power transister. It will be mounted to the power supply case. Replace this transister and try to operaste your radio again. Make sure that the power supply you use is at leat 7 amps or the radio will not operate properly and you will possibly blow the transister again.
Jul 16, 2011 | Radio Communications
Amp won't power up,anymore! Even with new parts installed,removed
Hiya, dont have a diag either what you will have to try and is compare the left channel with the right. There will be 2 driver transistors (also likely on heatsink) close to the outputs. Check which driver drives which output on the left, then match it on the right. Those same drivers could very well also be a problem on the right as they often go with the outputs. There is a possibilty they have smoked again. See here to test FETS
http://www.4qdtec.com/mostest.html
Basically the left will match the right but not similar locations but definitely by track joins.
Also check the power resistors at the output. Often also go.
Hope that helps
Jul 15, 2009 | Car Audio & Video
Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Apr 30, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Feb 20, 2009 | JVC Audio Players & Recorders
JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
Feb 20, 2009 | Pioneer VSX-D511 Receiver
Jvc tv
check for fly back transformer
but remember that before you replace any thing in eht section check for power supply output to be ok.
also check for diodes,capacitor connected to flyback transfomer.
also check for mica sheet is not cracked or h/output is not touching to chassis.
good luck
Nov 01, 2007 | Televison & Video
Car Audio & Video Logo
341 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
