Question about LG WM1812C Front Load Washer
LE error code
Gives LE error code. Makes funny noise. Of course out of warranty. Only two yrs old. Tried unplugging-doesnt work. Where do I turn down the heat setting for the water?
  • jweichelt Feb 14, 2008
    Washer is also almost 2 years old and cant clear the le code. Tryed unplugging for two hours. When it starts it makes a squeeling noise from the stator sensor on the back. Drum spins free when off. I have been waiting for a repair person for two weeks and they might get over next week Wednesday. I suspect a bad stator on the back of the drum. Any ideas?
  • sudatha Jun 22, 2008
    LE error code comes with high frequency noice.
I have this washer and the LE error code generally comes on when there is hair and lint (and maybe a hairpin or coins) in the lint trap in the little lint trap on left bottom corner. Take a standard screw driver or quarter and pop open the hatch door. Pull the small black drain hose off the hook and drain into a pan or larger bowl after pulling little plug out of hose. Don't pullbefore you have something to drain it in, all the water will go all over your floor. Then there is a white basket that you unscrew and pull out whatever is caught in the trap. I have two girls with VERY long hair and three dogs. Usually this machine will give me the LE error after I have washed dog bed covers about every other time. It doesn't happen often, but it usually is hair balls basically. Otherwise no problems and love the machine.
Posted on Mar 13, 2008
  • LG Master
  • 909 Answers
I feel you could simply have a blocked drain pump. is there water still in the unit when the code LE comes on. if so simply remove obstruction and try running unit again.
Posted on Sep 21, 2007
  • 641 Answers
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire or a dislodged ball sensor. Good luck!
Posted on Aug 21, 2007
SOURCE:
LG WM1812C Front Load Washer Logo
715 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
