The door is shut but keeps getting error
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
[email protected] for more info.
SOURCE: keep getting de error code display for LG WM0642H
Call for warranty service should be in warranty for a year.
SOURCE: I am getting error DE
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
SOURCE: my machine lg top loader
this means door error there is a magnet in the lid that falls of and this is how the computer knows the lid is shut lg dont sell the magnet you have to replace the whole lid sorry.
SOURCE: LG wf-t6517tc, stop after fill
Strange that it should fill as that means door error. You would think it would not fill if it thinks there is a door error. Have you tried switching off, unplug leaving for a few mins? If you can empty it check the door seal,/ latch it may require a new door switch.
Also check that the pump filter is not partially obstructed, be careful water will come out when you check. I read that in another post, I also read that it means drain error but that is at odds with what is written here: read this below it should help and there are pictures
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
regards
