Question about LG Prada KE850 Cellular Phone
Checking my aol email
I did set up the aol account under message setting but under network profile I don't see any selection for the email so how am i suppose to connect. I noticed the port for aol is 143, will I have to check that somewhere on the setting? when I enter through my broswer under aol website, still not able to check email. when I went into message and email i dont see any inbox mail that are in my aol mail
Perillo66
Posted on Jan 21, 2008
SOURCE:
Set up email, wont acknowledge,vant find server,etc. Cant sync aol email, cant use any email onthis????
To setup AOL/AIM as an IMAP account on your DROID X:
To setup AOL or AIM on your DROID X once you have already set-up your handset, follow directions below. If you are adding the account during your handset's initial startup, skip down to Set-up account menu (Instruction #3).
  1. Open Applications tray, touch My Accounts
  2. Select Add Account
  3. You will be at the Set-Up accounts menu with several other social network icons.
  4. Select Email icon
  5. Enter your full AOL/AIM email address, including "@aol.com" or "@aim.com" domain name in all lower case.
  6. Enter AOL/AIM password.
  7. Leave Automatically configure account checked.
  8. Tap on Next. Handset will connect to your email server and state "Success!" if account was set-up correctly.
Feb 26, 2016 | Cell Phones
LG PRADA - setting up MMS and INTERNET
Kevklau, From your problem description it appears that you know how to operate the phone. Before looking into further advanced setup options, you should know that the problem might be with your service package: MMS and internet service must be enabled by your cellular service provider. Try contacting your cellular provider to enable your MMS and internet in your service package. If that is not the problem, please reply for further information.
Aug 06, 2007 | LG Prada KE850 Cellular Phone
I dont know how to set up my aol email account on my samsung galaxy fone
Follow the directions below to setup email on Galaxy S,
Set up an email account
1 In Idle mode, open the application list and select
Email.
2 Enter your email address and password.
3 Select Next (for general email accounts, such as
Google Mail and Yahoo) or Manual setup (for other
company email accounts).
4 Follow the on-screen instructions.
When you are finished setting up the email account, the
email messages are downloaded to your device. If you
have created more than two accounts, you can switch
between email accounts; Press [ ] ? Accounts and
select one you want to retrieve messages from.
May 18, 2011 | Cell Phones
Can I configure microsoft outlook 2007 to work with my yahoo e-mail if i'm connection through clearwire at home and I'm not on a network
If you are not connected to the internet, you can only work offline, and for example, if you write an email it will not send until you do connect to the internet.
You can configure Outlook 2007 to work with Yahoo.
If you want to "POP" your Yahoo! Mail into your Outlook 2007 application, here's how:
  1. From the Tools menu, select "Account Settings." If you do not see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the Email tab, click New.
  3. Check the box next to the first option, "Microsoft Exchange, POP3, IMAP, or HTTP" and click Next.
  4. In the Your Name box, type your name as you'd like it to appear when you send a message.
  5. In the Email Address box, enter your Yahoo! Mail address (for example, "[email protected]").
  6. Check the box for "Manually configure server settings or additional server types" and click Next.
  7. Check the box next to the first option "Internet E-mail" and click Next.
  8. In the Server Information area, under "Account Type" select POP 3 from the pull-down menu.
  9. In the Incoming mail server field, enter: pop.mail.yahoo.com.sg
  10. In the Outgoing mail server (SMTP) field, enter: smtp.mail.yahoo.com.sg
  11. In the Login Information area, in the User Name field, enter your Yahoo! ID (your email address without the "@yahoo.com").
  12. In the Password box, enter your Yahoo! Mail password.
  13. Check "Remember Password" if you don't want Outlook to prompt you for your password each time you check your mail. Handy!
  14. Do not check the box labeled "Log on using Secure Password Authentication (SPA)."
  15. Click on the More Settings button.
  16. Click on the Outgoing Server tab and check the box next to "My outgoing server (SMTP) requires authentication."
  17. Click on the Advanced tab.
  18. Under "Incoming Server (POP3)", check the box next to "This server requires an encrypted connection (SSL)". The port number in the "Incoming Server (POP3)" field should automatically change from 110 to 995. If it doesn't, make sure the port number is set to 995.
  19. Under "Outgoing Server (SMTP)", check the box next to "This server requires an encrypted connection (SSL)". Enter port number "465" in the "Outgoing Server (SMTP)" field.
  20. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, don't check the box.
  21. Click the OK button.
  22. Click the Next button on the Email Account Wizard, then click Finished.
  23. Would you like your Yahoo! Mail inbox to be your primary inbox in Outlook 7? If so, click the Tools menu and select "Account Settings." If you don't see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  24. From the list, select the pop.yahoo account you've just added and click the Set as Default button.
  25. Click the Close button. You're done!
Troubleshooting instructions
If you followed the above configuration steps, you should be all set. However, if you cannot send or receive mail with your email client, try the following tips.
The Yahoo! Mail SMTP server requires authentication. Make sure you have enabled SMTP authentication. To turn this setting on, follow these steps:
  1. From the Tools menu, choose "Account Settings."
  2. Select the "E-mail" tab.
  3. Select your Yahoo! Mail account and click Change.
  4. Click on the "Outgoing Server" tab.
  5. Check the box next to "My Server Requires Authentication."
  6. Please make sure that "Log on using" is not checked.
  7. Click OK.
To control deletion of messages from the Yahoo! Mail server:
  2. Click on the "Email" tab.
  4. Click on the "Advanced" tab.
  5. Check "Leave a copy of messages on server" if you want to save your Yahoo! Mail messages on the Yahoo! Mail server as well as on your local computer. Please note that setting your email client to remove messages from the server will cause your messages to be deleted from the server. Once the messages are deleted, we are unable to retrieve them.
  6. Click OK.
  7. Close Microsoft Outlook and restart.
We strongly recommend that you enable SSL for both POP and SMTP, as detailed in the above instructions. This will ensure that your Yahoo! ID, password and email messages are transmitted securely between your mail client and the Yahoo! servers. However, if you choose to not use SSL for SMTP, your email client will likely default the SMTP port to 25. If your ISP blocks port 25 or if you're unable to send email, then you will need to use port 587 when sending via Yahoo!'s SMTP server. To make this change, please follow the directions below:
  1. From the "Tools" menu, select "Account Settings"
  2. Select your Yahoo! POP account and click on Change.
  3. Click on the "Advanced" tab.
  4. Click OK and Close.
May 05, 2011 | Microsoft Office Computers & Internet
As soon as I sign in it goes to my email, then it says diagnois computer network, I cant check my email what can I do, it also does this when Im at yahoo
Thanks for visiting FixYa!
Yahoo has been experiencing a system wide problem. Many of Yahoo! Mail customers are experiencing the same problem as you.
To assist Yahoo mail customers with this problem, AOL will transfer all of your contact information and future emails from your Yahoo account to your new AOL account for the next 30 days for free. (Until Yahoo can correct the problem). You won't miss any emails from your Yahoo account.. They will be automatically forwarded to your new AOL account.
Here are the instructions:
1) Go to AOL and set up a new AOL email account. (Click on this link) https://my.screenname.aol.com/_cqr/login/login.psp?seamless=novl&locale=us&offerId=newmail-en-us-v2&siteState=ver%3A4'rt%3ASTANDARD'at%3ASNS'ld%3Awebmail.aol.com'uv%3AAOL'lc%3Aen-us'mt%3AAOL'snt%3AScreenName'sid%3Af27fcb24-926a-4b22-ac39-ac0d19e1d3f4&authLev=0&sitedomain=sns.webmail.aol.com&lang=en
2) During the set up process you will be asked to provide a security question. Later, you'll need to answer the security question to set up the transfer, so don't forget the answer.
3) Once your new AOL account is set up, go to your AOL email page. Look in the upper right hand top corner for the word, SETTINGS and click on it.
4) (Next page) On the left hand side, look for the word, Accounts and click on it.
5) (Next Page) Look on the line beginning with, Transfer Accounts and locate the link that reads, AOL Easy Transfer and click on it.
6) (Next Page) Agree to the terms of service and click on, Get Started.
7) (Next Page) Under Copy from, enter your Yahoo email address and password.
8) Under Copy to, enter your new AOL email address and password.
9) (Next Page) Carefully Read, and select the options you need. (Click, Continue)
10) (Next Page) Click, Go to AOL Mail.
11) (Next Page) Enter the answer to your security question you created when you set up your new AOL email account. (Click, Continue)
12) (Next Page) Look at the top Left hand corner and click on, MAIL.
That's it. (Although AOL says that it may take up to 24 hours to complete the process - it usually only takes about 30 minutes.) After you receive your confirmation email, Click on your Contacts in your AOL account. When you see your Contacts from your Yahoo account there, the transfer has completed.
Feb 25, 2011 | Yahoo Mail
My yahoo mail will not open messages. This is a new problem.
Yahoo has been experiencing a system wide problem. Many of Yahoo! Mail customers are experiencing the same problem of being unable to open email.
Feb 24, 2011 | Yahoo Mail
The error, LaunchEmptyResponse, occurred when trying to connect to Yahoo! Mail. Error im getting
Yahoo has been experiencing a system wide problem. Many of Yahoo! Mail customers are experiencing the same problem (the launch empty response message).
I can recieve my United Kingdom hotmail on my samsung jet but I need the settings to send emails
hi,you need to change your smpt server to smpt.t-email.co.uk and you do not need your SSL on.. it took me ages to suss this out.no tecnicions could even help!!
Jul 30, 2009 | Samsung Jet S8000 Cell Phone
Checking aol mail
To send and receive emails via your LG Prada phone you will first need to set up an email account Send and Receive emails on your LG Prada phone by setting up an email account. To set up a new account: From the Start-up screen select the Main Menu icon Select Message (Figure 1) Scroll down and select Settings (Figure 2) Select Email (Figure 3) Select Accounts (Figure 4) Select Menu icon Select New Account (Figure 5) You will now be required to enter some information relevant to your network provider (details of which you can find here) and existing email account: Account Name ? For example ? Hotmail, Gmail etc (Figure 6) Email Address ? e.g. [email protected] Your Name ? e.g. Bob Jones Incoming Mail Server ? Click here to find out this information (Figure 7) User Name ? e.g. bobjones Password ? This is will be the same as your Gmail/Hotmail password Outgoing Mail Server ? Click here to find out this information (Figure 8) You can also set up some Advanced Settings on your email account, to do this press the Menu icon and select Advanced Settings (Figure 9). You can now edit the following settings if you need to do so, however, they will already be set to default settings: Protocol Type (Figure 10) Maximum Receive Size Save To Server Insert Signature (Figure 11) Reply Email Address (Figure 12) Incoming Port Number Outgoing Port Number (Figure 13) Outgoing Mail Authen (Figure 14) Outgoing Server ID Outgoing Server Password Once you have completed the above, press Save the in the Email Account section activate your new email account (Figure 15). You are now ready to send and receive emails. You can also change your Network Profile and set up a Signature via the main Email menu simply select Network Profile then the new profile and activate. To set up a Signature choose Signature, then New and write your Signature and press OK
Aug 18, 2007 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
151 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
