Question about Harman Kardon AVR 25 MKII
I turn it on, it clicks off within a few seconds.
When I turn on my receiver, within a few seconds it clicks off. I have removed the cover. The fuses are all good. I have lifted up the board that has the rear speakers, center speaker, antenna, etc... however, I do not see any obvious burning or broken soder links. It stays powered up long enough to change from say phono to tuner. I believe it became to hot. Some of the tabs that hold items to the board described above, that are plastic show signs of slight melting.
  • jricke Dec 01, 2007
    I have a h/k avr 520 that is doing the same thing. When the sb button is pressed and turns green, the unit turns on and the display flashes wtih info and then turns off.
    JRicke
  • Anonymous Dec 24, 2007
    we have a AVR 630 which we are about to throw away because no one can seem to fix it. it will only stay on for a couple minutes, then each time it stays on a shorter amount of time. the repair shop said it works for weeks on end for them. now we have a Monster power filter, which we were hoping would solve all problems - but it didn't - the same thing happened - it turned off.
It sounds like a problem with the power supply. You might be able to find a place that can fix it, but I don't know for sure. It also could be a broken solder joint in the power supply.
Posted on Jan 12, 2009
    Problem Solver:
  • 7 Answers
Can you be more specific as to "plastic tabs that show signs of slight melting"? Like where are they in relation to components / power supply / heatsinks / power transformer? A first shot... it may be output power fets/transistors (one is open or shorted) that is making one or more of the speaker outputs go to the PS rail. DC shutdown. Does this receiver indicate any "overtemp" or "protect" warnings? I really need a little more specifics.
Posted on Aug 20, 2007
After a power outage my denon 2803 receiver will not turn on.
Hello. First unplug and replug in your receivers. When you push the power button, you should hear 1 click. Within 5 seconds, you should hear a second click. Can you please tell me the results?
Thank you.
Sep 15, 2012 | Denon AVR-2803 Receiver
Whenever I turn on my receiver, it stays on for a few seconds, then switches off.
Sound like a semi-component is faulty within the unit you need to get it serviced. Does it indicate any thing on the LCD when powering up before it dies ?
Oct 13, 2011 | Onkyo TX-SR803 Receiver
Fridge is plugged in and turned on, but motor seems to be trying to turn on, but isn't, and the fridge is very warm. There's a click, like it's trying, then after about 3-5 seconds there's another click,...
Greetings,
if your refrigerator is making a clicking sound every few minutes. It could be the relay burnt out. i would remove rear cover and locate compressor terminal cover and remove...pull of the relay,it will be the part that conects to two pins on the compressor...shake it, and if it rattles, its bad....
Dec 19, 2010 | KitchenAid Refrigerators
Cannot get mouse to work
1.
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
3.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
5.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
6.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
Unit only has power for a few seconds
Yeah remove the unit from your car,
Go to car audio store and buy Kenwood receiver without the
fancy opening front.
Dec 17, 2008 | Kenwood eXcelon KDC-X879 CD Player
Epson i880 Waste Ink pad location
try this plz dont for get to rate
1. Turn the printer off.
2. Hold down the ink and paper buttons, and turn the printer back on.
3. Within a few seconds, the paper light will start flashing quickly. When it does, let go of both buttons.
4. Within 3 seconds press (and hold) the ink button.
5. Hold it until all three red lights start flashing (about 10 seconds).
6. Let go of everything.
7. Turn the printer off, and back on.
Dec 07, 2008 | Epson Stylus 880 InkJet Color Printer
Onkyo receiver with no sound
There should be 3 clicking sounds coming from the amp. You amp miss the last clicking sound coming from the speakers ,spk, output terminals. There should be 3 relays on the spk output board. Their 12 contact points may have a layer of black colour oxide. Remove the oxide can fix the problem, perhaps.
1. Unplug the amp.
2. Open the cover
3. At the spk terminal, there is a horizontal board.
4. Look for the 3 relays and take them out.
5. Open the relays and remove the oxide layer by a sandpaper.
6. You need an iron solder, a desoldering pump and solder.
7. If does not help, check for the 24V for the 5 relays. 2 is for B+ and B-.
Sep 08, 2017 | Onkyo TX-SR501 Receiver
Htr 5590
Mine played for about and hour then cut off. It would cut off randomly after this hour. I initially thought it was overheating but after seeing other people had it happen after immediate turn on it must not be the case. Intermittent problems like this are difficult to troubleshoot which is why I came to this site hoping someone had found a simple answer. I am a technician and will have to do it the hard way. When I find the answer I will report my findings to this site.
Apr 14, 2008 | Yamaha HTR-5590 Receiver
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
582 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
