SOURCE: magnavox tv 42mf439bf7....no picture and
Hi Thanks Rylee
Thanks for using FixYa. From what
you have described it seems the issue is with the power board or the main board
and we'll need to check few things. When you open the unit up; take a look at
the power board-the board where the power cords/plugs goes into. You might see
some filter capacitors a little bulged up in the top-If this is the case-this
is your defective part(you can try to replace them-but some soldering equipment
is needed). If not, then probably the main board has gone bad. This is the other
board-where all the inputs are going into. All this is only recommended if you
have electrical expertise and know how to solder/re-solder components. Please
note that the TV components consists high voltages even when in off position. Please accept the solution if the issue is resolved or post a comment for further
assistance.
SOURCE: I brought a onn universal remote to turn on my magnavox converter box what code do I use
Try the code 0759
Ajin
SOURCE: magnavox 42mf439b/f7, no picture or sound
i have set with same problem in my shop and after troubleshooting i found that the problem is in jack mo dual A91h5mjc. when you plug set in you hear relay and turn on when you push power switch after few sec high voltage supply shuts down making light blink. what they did is separate high and low voltage supply's half one one board half on other to confuse everyone.
SOURCE: repair magnavox tb100mw9 digital tv converter
You can probably find a lightly used replacement for less than the cost to repair.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
