Guest - the website for Cuisinart is www.cuisinart.com, and their phone number is 1-800-726-0190. If your product was purchased at Sam's, Costco, or BJ's, then your model # may not show up on their website, but they will have an equivalent that they can give you over the phone.
Who is the manufacturer and what is the model # of the coffeemaker?
Same Problem
Mar 27, 2009
-   I have same problem.. water leaking form bottom.. Is seal broken-   gpalber1
Mar 22, 2009
-   This is very frustrating. I thought I was pouring the water in the wrong place. The Cuisinart website doesn't have a tech support line. -   Guest
looking at the bottom of the cannister, you will see a stainless steel plate about 3 inches in diameter,, 6 screws hold it in place.. check the screws to make sure they are tight.. tork them down equally.. If that does not stop leak.. check to see if there is debris in the spout.. it simply pushes up to let the coffee out..a rubber washer acts as the stopper. clean it as best you can with qtip.
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
