Question about HP Photosmart R927 Digital Camera
HP R927 Camera
Camera will not turn on out of the charging dock. We have replaced the battery with a new one....and still the camera will not turn on. While in the charging docking station the camera will turn on. The charging light does not come on while in charging dock. We have charged the battery overnight.....and camera still not working outside of charging dock. This is a new purchased camera.
  • Frejaviole Nov 16, 2007
    Same symptoms but cleaning the battery contacts didn't help - anyone any other ideas?
I had this problem with this camera when i had it new i would put the camera on the dock to charge and then use it then finally it wouldnt work and i realised that the camera wasnt charging. i contacted hp who i found to not be very helpful, they eventually sent me out a new battery even tho i told them i felt it wasnt the battery, of course the same thing happened with the new battery. i called them again and said i felt that there may be a loose connection in the wire going from the transformer to the dock as by messing around with it had made the light come on but as soon as i let go it went off, they agreed to send a replacement. when the replacement arrived they sent the part of the cable that plugged into mains and as such was no use, they siad they would send the right one but as yet i have not received it. =S however, by moving the wire where it plugs into the dock i have manged to get the camera to charge, it may be worth messing with the wire to see if this is the case with urs and calling for a replacement. claire xx =D
Posted on Jul 17, 2008
I also have problem ~ 1 year old.
How do you mean scratching contact inside camera?
Posted on Nov 29, 2007
I had this problem with my camera after a year. Scratching the battery contact terminal inside the camera fixed it.
Posted on Nov 11, 2007
I got thsi same problem. i lent it out and it came back like that.
Posted on May 02, 2008
SOURCE:
Constant Charging Flash HP Photosmart R927 digital camera
First I'd try turning the flash off, a manual option on nearly all camera's. Take a couple of photo's without flash, and turn the camera off and on a couple of times then turn the flash back on to auto.
If that doesn't resolve the problem, I suggest going to the HP website, follow links to support and/or downloads and see if there's a firmware upgrade for your camera.
Apr 26, 2010 | HP Photosmart R927 Digital Camera
My Photosmart R927 will not turn on. I installed
Assuming that the new battery was the correct type and that it was fresh/fully charged, your problem may be due to or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 12, 2009 | HP Photosmart R927 Digital Camera
The battery is not charging. Do I need to buy a
to fix your problem try to buy a new battery then see if the camera works if it didn't return the battery and then buy charger may be the chargers fault.
Oct 11, 2009 | HP Photosmart R927 Digital Camera
Not able to charged battery nor power the camera. The camera is completely dead.
Do make sure you have new batteries and new charger. If problem persists, then I would have the charging circuit may need to be tested or replaced
Aug 14, 2009 | HP Photosmart R927 Digital Camera
Camera won't charge on dock
usually this happens to old cameras and other devices. is your camera old?
Aug 11, 2009 | HP Photosmart R927 Digital Camera
Hp r927
Sounds like blown flash bulb.
Needs to be replaced.
Mar 19, 2009 | HP Photosmart 735 Digital Camera
R927 will not power on.
i had this problem with this camera when i had it new i would put the camera on the dock to charge and then use it then finally it wouldnt work and i realised that the camera wasnt charging. i contacted hp who i found to not be very helpful, they eventually sent me out a new battery even tho i told them i felt it wasnt the battery, of course the same thing happened with the new battery. i called them again and said i felt that there may be a loose connection in the wire going from the transformer to the dock as by messing around with it had made the light come on but as soon as i let go it went off, they agreed to send a replacement. when the replacement arrived they sent the part of the cable that plugged into mains and as such was no use, they siad they would send the right one but as yet i have not received it. =S however, by moving the wire where it plugs into the dock i have manged to get the camera to charge, it may be worth messing with the wire to see if this is the case with urs and calling for a replacement. claire xx =D
Apr 03, 2008 | HP Photosmart R927 Digital Camera
R927 digital camera
Are you sure that the battery is holding a charge? If it is holding a charge check the contacts on the battery and inside the camera. you can clean both of them with a pencil eraser gently rub the eraser on the contacts and this will clean them. I hope this helps you out and fixes your problem.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
R927 wont turn on
Remove battery and clean contact and then try.
Make sure the battery is fully charged or fresh
If still in trouble contact HP Support
Nov 27, 2007 | HP Photosmart 935 Digital Camera
HP Photosmart R927 Digital Camera Logo
252 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
