Question about Viking DDBB363 Bottom Freezer Refrigerator
Ddbb362 viking designer
The alarm went off indicating the door was open. Door was closed, I turned off alarm at 11pm. The next morning, I opened the fridge and hot air came out even though it was blowing cool air. It turns out the electronic panel at the top was VERY HOT. So hot that the plastic at the top of the fridge below the panel was hot to touch and the seam was even broken. It looks like a short in the panel because every time I reset the alarm, it goes off again. The freezer works fine, but needless to say, the fridge is shut down. It looks like my electronics are fried.The warranty states six years parts and labor for sealed refrigeration system and ice maker and 12 years parts only for sealed refrigeration system. Two years parts and labor for complete unit. My unit is four years old and I have a feeling electronics fall into the two year window. Am I covered? If not,how do I pull the panel and what is the damage in dollars?
  • Anonymous Nov 20, 2007
    Had the same issue with my Viking DDBB...thought the same thing because of the heat observed aorud the control panel. The lever switch in the upper right corner of the door was broken, keeping the interior lights on all the time. This over-runs the cooling system and shuts it down. I replaced the switch myself (tight) and all is great. Happened right at the two-year point. If you need a switch, I found them in a surplus electronics joint in Orlando Florida for $1.50 each...let me know. ssvtinc@aol.com
  • New Viking Jun 23, 2008
    I guess I didn't close the door closely and left, after I got back an hour later, I hear the beeping sound, turned off the alarm, couple minutes later, the alram is beeping again. Looks like the top panel is not working and I couldn't find the switch which is supposed to be the top of the door. I think the fridge and freezer are shut down since the temperature is high for both.
In my oppinion, it seems the problem with the condensor fan motor.
Posted on Sep 27, 2007
  • 183 Answers
It sounds like the light switch may be keeping the light on when the door is closed. Faulty Switch. Regards Advisor
Posted on Aug 21, 2007
  • Bob-A-Lou Anna Maria
    Bob-A-Lou Anna Maria Jun 02, 2015
    Useless response
    I have this same issue. You can manually press the switch and watch the lights go off, and the refrigerator still thinks the door is open.
    I even removed the switch which is a normally closed switch, and even with the switch gone (lights in fridge off) the fridge alarm will sound. You hit the alarm off button to ignore, and a while later it'll sound again. It does this at random intervals throughout the day and night.
    The light switch apparently has nothing to do with whatever the fridge is using to monitor the open door.
Internal fan in refrigrator dont work & noise of door alarm repeat every minute without door opening
My best guess is the 'door closed' sensor is not working correctly, to verify, open the fridge door, find the button the would be pushed when you close the door (often on the hinge side). Push the button with your finger and if the light goes out and the fan starts up, it needs adjusting. If the light does not go out, it needs replacing.
Good luck.
Mar 02, 2015 | Refrigerators
How can I turn the door alarm off in my samsung fridge?
the alarm indicate that the door is open
check the door switch and check if the door press the switch or not
I think the door latch didn't reach the switch
Jun 07, 2014 | Samsung RS2630WW Side by Side Refrigerator
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
Alarm went off, now the central locking doesn't work
use the car key itself from outside the vehicle with everything closed: use key in drivers door outside door lock and manually lock and unlock the door. check if fixed, may have to do a few times. i do believe the vehicle is in theft mode.
Aug 18, 2012 | 1994 Volkswagen Golf
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
New door fitted on Larder integrated fridge but door alarm sounds inspire of door being closed.Digital display indicates door open.
The old door had a hidden trigger that signaled when the door was closed.
You need to retrieve the trigger from the old door and fit to the new door.
Mar 31, 2011 | Electrolux Refrigerators
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
I opened the door on GE Profile side by side refrigerator this morning. Not only was the the refrigerator not blow cool air. It was actully blowing hot air, it was like opening the oven. The temperature on...
Check if it is still under warranty - I think that it is usually 2 years.
When in this condition, was the compressor still running ?
There was one issue that occurred occasionally on some models - the fridge door has a height adjustment so you can level the 2 doors up. Sometimes, it drops a bit too much, and on models with the fridge door light switch on the top (not the side), it meant that it wasn't turning off the light. Some have 2 lamps (commonly 40W or more each), so you effectively have 80Watts or more of heating running constantly. If your (exact) model has the door switch on the side, this is Unlikely to be the issue.
If the compressor was not running, I could say something like "it might have got stuck in a defrost cycle", but this DOESN'T really fit with the operation of these fridges (no defrost elements in the fridge side).
Does this help in any way ??
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Viking DDBB363 Bottom Freezer Refrigerator Logo
767 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
