Question about Sony Cyber-Shot DSC-F717 Digital Camera
Washed out When I take a picture, it comes out all white washed and there are little lines through entire picture.
  • 31 Answers
CCD picture sensor gone bad, very common problem for Sony cameras, Sony offers free repair, go to Sony support site, follow this link:
Posted on Aug 20, 2007
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
When ever there is some strong white on the screen it gets distored. For example. There was a white tent on screen and where the light was hitting it it was extremely pixelated and distorted. Ny ideas?
This fault can occur to mainly three reasons. ABL circuit failure. Low screen voltage or lack of emission from picture tube cathode. Just advance the screen voltage to a little, and observe the result. Screen control can be located on its Line Output Transformer [LOT]. there will be two variable controls built on to LOT marked as screen and focus. Screen control will be at lower side, and focus will bw on the top. Just advance [clockwise movemnt] to a little, not more, advance it till retrace lines are just visible on the screen. Before doing this, set all the picture controls, contrast, colour and brightness of the TV to zero. Once the retrace lines[thin horozontal white lines across the entire screen at about 1 inch distance with each other]; are visible, stop there, turn the screen control counterclockwise to just a point when these lines are just goes off. make this adjustment in a dark room so that you can set this point very correct. After this check the perfomance of the picture. If this does not help you, ABL circuit should be checked for any fault.
If emission of the picture tube has got down, even the screen adjustment said above won't help you. The only way is to replace the picture tube with same type and number. OK.
Apr 16, 2011 | Sanyo DS24424 24" TV
Lost all picture detail in camera
See this link. You have the classic symptoms of image sensor (CCD) failure. Canon will fix this for specific models (yours included) at no cost regardless of warranty status. If you don't live in the US, contact your regional Canon service agency.
Apr 08, 2009 | Canon PowerShot A70 Digital Camera
Casio exilim ex-z700
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Aug 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Photos have horizontal lines
Ok, first of all......when you transfer the pictures to a computer are the blue lines still in the picture? Also if you reset the camera does the image still come out white?
A lot of times what happens is that there is nothing wrong with the actual picture it is the lcd. When you transfer the picture it looks ok you are only seeing the blue lines on the lcd. That means that the lcd is going out. If you transfer the picture and the blue lines are still in the picture after transfer then we can try to reset the camera as there is something else going on besides the lcd. More that likely it is just an lcd that needs to be replaced.
With a white image that usually means that the white balance is off on the camera. I would recommend resetting the camera and then try retaking some pictures to see if they are still coming out white. If they are then you would have to send the camera in to be repaired.
Jun 22, 2008 | Casio Exilim EX-Z750 Digital Camera
White lines across TV screeen
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
May 08, 2008 | Televison & Video
Need Help!!! Please...
Sounds like a setting try setting it to default un the setup menu if that does not help then the CCD need tobe replaces most likely. Hope this helps.
Mar 10, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Pictures with White Lines
Same problem with mine!  Fine Any suggestions?
Oct 28, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
White lines, all white pictures
I have the same problem have you been able to fix it ?
Sep 23, 2007 | Pentax Optio M20 Digital Camera
White washed
there has been a product recall on these cameras as the sensor has malfunctioned and this sounds like whats happened to yours.If you call sony on 08705143480 and speak to them and tell them that you need the details of the product recall then they will run through it with you and if it is the same problem as I think then all you have to do is send it off to sony and they'll replace the sensor free of charge
May 05, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
119 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
