Question about RCA 32V550T 32" TV
Tuner Problems The tv when plugged into the cable will pick up and tune some digital channels, it will not show any analog. Also when connected to the cable it will mess up the high speed internet for the house? Any ideas? Thanks
    Genius:
  • 1,139 Answers
OK the tuner may be causing these problems, however first I would like you to go to your menu and set the RF pickup to antenna (This will allow analog channels) then come out of the memu and select a channel in the analog range channel 4, 7, or 9 try to tune in these channels. If this fails then you may have tuner problems the only way to be sure is to use a RF signal generator to send RF through the tuner and see if the video and audio being carried on that signal comes through. Sometimes the Internet connect gets messed up when the TV does not have the proper RF filters this may be your case. Try this use a Cable tv set top box and just set your TV to channel 3 for cable. This should Isolate the TV from the Internet cable modem and provide the signal needed by the TV.
Posted on Sep 19, 2007
SOURCE:
Can't change channels stuck on 4 tried scanning it but it goes back to 4 won't change on the tv or a remote
When you run a scan the TV changes to every channel and tries to tune in a station. that is why it takes so long. If your TV is only finding channel 4, I would guess that is the only station strong enough for it to pick-up. You should check and / or replace your antenna and or antenna cable. Then re-scan the channels. with a better antenna, it should find more stations.
Most older Tube type TVs need a converter to pick-up digital TV, if you have a converter, make sure it is plugged in.
You should not be getting any stations without a digital tuner TV or a converter box.
The FCC site says this:
The FCC established September 1, 2015 as the date for the termination of all analog low-power television service. Since that date, analog television should no longer exist in the United States. Until that time, LPTV stations were allowed to continue to operate their analog facilities.
Jan 28, 2016 | Televison & Video
Please can anyone help i cant tune my tv it wont pick up any channels when i auto tune it it says weak or no signal but i plugged aerial and tuned another tv and its fine
Are you trying to get over the air channels? IF you are does your TV have the digital tuner on analog? TV went digital and if you have an analog tuner will need either e new TV or converter box.
Jul 01, 2015 | Samsung 65" F9000 Series 4K Ultra HD Smart...
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
CAN I USE MY EMERSON EWD2204 AS A DIGITAL TUNER TO RECEIVE CABLE ON MY ANALOG TV
No. It's tuner is analog. However, your cable company may still broadcast some analog channels. But if that's the case, your TV will pick up the same channels.
Feb 01, 2014 | Emerson EWD2204 DVD Player/VCR
When I got the remote control and started the channel setup, it only picked up Digital channels, and I don't know how to have all of the other cable channels show up. The channel numbers come up like...
This is a newer TV. It doesn't have an analog tuner. You will have to buy the analog to digital converter box and re-scan your channels, or switch to a digital cable/dish provider.
Aug 26, 2011 | Televison & Video
How do i tune in my digital cable on my analog tv?
You'll need a digital cable box for that, I'm afraid. The analog tuner in the set isn't compatible with the digital cable signal. The cable company in my city just dropped their analog service. Now you either need a digital converter box, or a "cable box lite" called a digital transport adapter. For digital off-the-air broadcasting you need a digital tuner and probably an amplified or outdoor antenna. The analog TV is rapidly becoming pretty useless except as a display device as analog channels disappear.
Mar 11, 2010 | Curtis-Mathis CM19011 TV
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Catching one Channel Only
A TV card probably wont be able to tune it in...or decode(decrypt) it for that matter. Is a CableTv set top box plugged in? (the box your cable company supplies you with) -damian
May 01, 2008 | HP Expresscard TV Tuner For Windows Vista...
RCA 32V550T 32" TV Logo
151 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
