Question about Humax DRT400 TiVo 40-Hours Video Recorder
The dvd tray is jammed (due to child input)
Can this be repaired or can i replace the burner. please help
    Genius:
  • 1,153 Answers
If you can carefully take top off of unit you can possibly find out what is jamming tray. If removed may operate correctly.
Posted on Aug 20, 2007
SOURCE:
Child pulled dvd draw out of portable tv dvd combi, how do I repair it
If the DVD tray has been pulled out completely or manually pulled out too far and it will not retract on its own then the DVD drive is damaged and needs to be replaced. Although the DVD drive itself probably is a standard drive, on TV/DVD combo units the drive is difficult to replace and should be done by a qualified service technician or by a manufacturer authorized service facility.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Oct 09, 2014 | Televison & Video
Can I open a jammedDUW1616/ARR DVD
Look on the front of the tray where the eject button is There should be a small round hole, this is for ejecting a stuck disk. Just open out a paper clip and insert in to the hole and press until the tray opens.
Jan 31, 2012 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Hp officejet 8500 premier printer has paper jam alarm,also I don't see paper being picked up from input tray at all
Hi........................
Please click here for solution :-
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP 8500 Premier All-In-One InkJet Printer
The door will not open.
It may be jammed. There is an emergency release, though. Look for a tiny hole just under the tray. Insert a straightened paper clip or something similar into the hole. The tray should open.
Jul 03, 2011 | Sony DRX840U DVD-RAM Burner
Cd tray has jammed open
make sure that the cd/dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
click start control panel administrive tools computer management device manager scroll to cd/dvd rom you might see a yellow quaestion mark? right click to install drivers
if your computer came with a motherboard disc the drivers could be on it
hope this helps
Mar 23, 2011 | AOpen CRW5232/AAO PRO (913FD37502) CD-RW...
My Sony burner says "Child Lock" in the display and it won't function.
I can't get my Sony DVD GX315 off Child Lock. Please help!
Oct 10, 2010 | Sony RDR-GX315 DVD Recorder
Paperless paper jam
Ok, the paper jam ERROR could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced or repaired under warranty.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Sep 12, 2008 | Lexmark E320 Laser Printer
Unable to manually open the CD/DVD drive
There is a good possibility that the switch under the button has failed, especially if this drive has been used a lot. An electronics technician could replace the defective switch, but unless you have a good friend in that business, it will probably be cheaper to replace the drive with a new one.
Jan 13, 2008 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Cd rom tray open problem
normal problem for samsung cd drives . clean the rails of drives that which tray is commin out . it mainly caused due to the change ina laaingnment of drive tray
Dec 04, 2007 | Samsung (DSSMBK482448) CD-RW Burner
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Humax DRT400 TiVo 40-Hours Video Recorder Logo
64 people viewed this question
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
