Question about Braun Syncro 7680 Electric Shaver
Charging stand Yesterday, after about 2 years of use, when I returned my shaver to the charging stand and pushed down the top, charging part, into the shaver it would not stay down. I tried unplugging the shaver completely in an effort to reset it, cleaned the contacts, pushed the blue button on top of the charging portion, but nothing seems to work. Any ideas what's wrong or how to fix it? I've really enjoyed this shaver so far and would hate to have to give it up. Thanks.
  • emd1 Dec 10, 2007
    same problem, but after I moved it to a cooler storage area, it resumed working.
  • Anonymous Apr 25, 2009
    Base plug does not stay in
  • 3 Answers
I just had the same problem, where the top of the charger would not stay down. I tried a spring clamp to keep it in place, and that works like a charm! Try it!
Posted on Sep 14, 2008
    Novelist:
  • 124 Answers
Shaver Outlet makes the stand available separately, significantly cheaper than if bought from Braun. As of this writing, it's available for $18.99.
Posted on May 23, 2009
Same problem with me. I use duck-tape.
Posted on Nov 04, 2008
I had this same problem 2 years after I bought this razor. Guess what it's been 2 years since I took it in for repair and it's just broke again. You can either fix the base or if you bought it at a place like Costco try and take it back.
Posted on May 21, 2008
Had this problem several times, was repaired/replaced but after warranty Braun will NOT stand behind their products!!!!
Posted on Apr 28, 2008
Hello i have phillips cool skin shaver cant remember proper model of it but its the one with stand charge which fills up shaver with this skin balm and also there i small stand charger as well and none of...
Hi pi finch,
Below are some troubleshooting steps for this issue. If you have any questions or need additional assistance, Consumer Care can be reached at 1-800-243-3050.
Question Why does the shaver not charge when I place it in the refill & charge station? Answer
  • The adapter has not been properly inserted in the wall outlet
  • the small plug has not been inserted properly in the refill & charge station.
  • There is no electric contact between the refill & charge station and the shaver because the shaver has not been placed properly in the station. First put the bottom of the shaver in the station. Then push the shaver backward till it locks into position with a click. The indication lights on the shaver and the station light up to signal that there is proper contact between shaver and station.
  • There is no electric contact between the refill & charge station and the shaver because the contact strips are dirty. Clean the strips with a damp cloth.
Hope this helps. If so, let me know by rating this solution.
Aug 05, 2011 | Philips Health & Beauty
Can't get the 7526 cleaning arm to stay down on the shaver for charging, cleaning, etc. Is there a sequence e.g. hold the arm down then select a cycle, or select then push down? What is the blue button...
The locking mechanism in the arm is broken. This is a common problem with your model. To repair it you will need to purchase a replacement part. You will find the part at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
If repairing your existing clean and charge machine is not an option, you will find the entire machine available at the link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
May 08, 2011 | Braun Syncro 7526 Electric Shaver
Braun 5790 leaks and floods counter when charging/cleaning!
I figured out the problem for my Clean & Renew unit. Mine is 2 years old. About 3 months ago, I cleaned the buildup of whisker material from the TOP of the drain port [Left Side as you look at the unit] If you take out the cleaning solution cartridge and turn the unit upside down, you see the pump and the return ports. The return port is the smaller of the two. I found that there was a mass of dried whiskers in a few clumps clogging the return port. These clumps must have come loose and got caught within the drain port. I had noticed when I had the leaking problem I could hear bubbling just after the pump ran and the shaver turned off. I removed the clumps of whiskers and no more bubbling sounds and NO MORE LEAKS. My guess is that the fluid was draining back into the intake area and leaking on top of the cartridge. Hope this helps
Jul 30, 2010 | Braun Flex XP II 5790 Electric Shaver
I HAD PURCHASED A HQ8140 SHAVER 1 YEAR 9 MONTHS
This problem can be caused by a malfunctioning printed circuit board inside the shaver. This usually can be fixed by fully discharging the battery then fully charging it or disconnecting the battery then reconnecting it (if possible, most shavers has their batteries soldered-in).
Jan 09, 2010 | Philips Health & Beauty
Hi, My braun bs 5301 does not lock my braun 7630 shaver in anymore. at the top where it clicks into the bottom of the shaver, its not actually clicking in and now it doesnt charge or clean unless i hold it...
While holding the neck, pull up hard on the charging piece with the blue button.... You will not break it, it will go right back in after...
DO NOT try to remove the whole neck, just the button piece will come up, an inch or two (NOT OUT COMPLETLY) The wire will only allow you to pull it up 1"-2" so dont try to remove it....
Then look inside and you can see a spring, it's not attached to anything it's just resting in a hole. Pull it out and then push the top charging piece back down till it clicks in...
Now it will stay down on its own... I had the same problem and this work around solved it.
Oct 23, 2009 | Braun Syncro 7630 Electric Shaver
Oct 23, 2009 | Braun Health & Beauty
Top of cleaning stand came out, loose parts- can it be reassembled?
Buy another one and return the faulty one with the new one's reciept.
Jul 26, 2008 | Braun Syncro 7526 Electric Shaver
Top housing for the charging stand for a Braun Syncro 7680 Electric Shaver
I just experienced the same problem and came up with this solution. Use a spring clamp to keep the top of the charging stand in place. It works like a charm.
May 28, 2008 | Braun Syncro 7680 Electric Shaver
Braun Syncro 7680 Electric Shaver Logo
520 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
