I want to wire the astatic tug8 microphone to a yaesu ft 450 hf rig I am chief Communications officer for Emergency Management here in the Region 1 Connecticut and want to wire the radio at our EOC Center with this Microphone and want to get the * pin wiring diagram for it.
PDF
The FT-2000 is the 2nd Generation of the proud lineage of the FT DX 9000 Series, which represented a ... While leaving the pitch of the incoming signal unchanged, as well as "Narrow" notch filter ... on all modules the u-Tune system tracks your operating frequency, ... crafted using a heavy brass alloy (knob weight: 6.7 oz.
FT-2000 100 WATT & FT-2000D 200 WATT HF+6 TRANSCEIVERS ... Note: frequency coverage may differ in your country. ... The front panel's oversized 2.67" (68 mm) Main Tuning Knob is crafted using a brass JISC3604R alloy, for easy ...
PDF
FT-2000 Series FT-2000D 200 W Version with External Power Supply. FT-2000 100 W ... While leaving the pitch of the incoming signal unchanged, as well as the bandwidth ... on all modules the Āµ-Tune system tracks your operating frequency, although you ... crafted using a heavy brass alloy (knob weight: 6.7 oz./190 g), for ...
Your RF gain control needs to be turned all the way up to be able to receive signals and if you are on one of the HF bands like 40 meters or any HF band the squelch control needs to be all the way off! You do not use squelch on HF! When on VHF or UHF then you would rotate the squelch control just to the point that the background noise stops and go no further. Higher squelch settings will only block weak signals and your radio will be deaf! Squelch control rotated just to the point the background noise stops! NO SQUELCH ON HF. Turn the squelch all the way off on HF!
Are you looking for a downloadable copy or making one available?
If you are looking for a downloadable copy, say so, otherwise as you can tell, we're just guessing, which doesn't help anyone.
If you're making one available for other to download, then I would like to buy you a drink, because this would be so appreciated by yours truly and others with that same said model.
So, which one of the above is it, let us know and we'll respond ASAP.
